Warning message
Remote Callers can't hear ringback on E1
Apr 8th, 2014
I'm running CMExpress on Cisco 2911 with one E1 card and callers can't hear ringback when the call is actually ringing in the local site. They just hear one ringback on the establish of call and after that, nothing until the end-user off-hook the phone.
Can someone have an idea about this issue?
Tahnks in advanced for your help.
This is the configuration:
controller E1 0/0/0
 framing NO-CRC4
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country telmex
  release-guard-time 2
  disconnect-tone
  category 2
  answer-signal group-b 1
  caller-digits 4
  dnis-digits min 4 max 4
  answer-guard-time 500
  groupa-callerid-end
  dtmf timer inter-digit 250
  voice-card 0
 dspfarm
 dsp services dspfarm
voice-port 0/0/0:0
 cptone MX
dial-peer voice 7 pots
 description ### INCOMING CALLS E1-PSTN ###
 translation-profile incoming To-AA
 incoming called-number .
 direct-inward-dial
Overall Rating: 4 (1 ratings)
acampbell Tue, 04/08/2014 - 16:24
  • Green, 3000 points or more
Hi Tavo,
Can you try adding a line to your VOIP dial peer:-
Something like:-
dial-peer voice 2000 voip
desc *** VOIP DP TO CUCM SUB ***
destination-pattern 2...
session target ipv4:172.16.255.22
codec g711ulaw
progress_ind setup enable 3
Hope this helps
Alex
Gustavo Adolfo ... Tue, 04/08/2014 - 16:35
Hi Alex, your comment make me update my case, i'm actually runnning CME with SCCP and SIP phones registered on it and when i called to any of this extensions, anyone made ringback tone.
Thanks for your help.
acampbell Tue, 04/08/2014 - 17:03
Tavo,
What version of CME are you running and what is the router IOS version ?
You may be hitting bug CSCdw73507 if it is old ios 12.2 etc
Does the issue happen with both the sip & sccp phones ?
Alex
Gustavo Adolfo ... Wed, 04/09/2014 - 13:48
This my CME and IOS version:
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
The issue is similar to the bug CSCdw73507When a call come from PSTN, the Caller just hear one ringback, but my IP Phone rings normal.
This is my Incoming Dial-Peer
 direct-inward-dial
Thanks in advance for your help.
acampbell Fri, 04/11/2014 - 01:33
Tavo,
Can you try adding this to your global config
voice call send-alert
voice rtp send-recv
Hope this helps.
Alex
Gustavo Adolfo ... Fri, 04/11/2014 - 08:16
Alex,
I already added these commands, but this issue continues, Do you think my E1 Provider has some work to do about it?
Thanks in advanced for your help.
Tavo.
Gustavo Adolfo ... Fri, 04/11/2014 - 09:03
Caller who calls a DID don't hear ringback, but when a AA is playing and Caller Dial an Extension in that moment he can hear ringback.
Call -> DID -> CME -> AA (Unity) -> Dial Extension -> Ringback (YES)
Call -> DID -> CME -> Ringback (NO)
Aaziz AMHAOUCH Tue, 04/15/2014 - 05:17
 Hi Gustavo,
I have the same problem with the same Gateway (Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4) registered with CUCM 9.1
Did you resolve this issu ?
Thanks in advance
BR,
Aaziz
Gustavo Adolfo ... Tue, 04/15/2014 - 06:32
Hi Aaziz, i still have the issue.
Let me know if you have any kind of suggestion.
Thanks a lot
Tavo
Ayodeji Okanlawon Tue, 04/15/2014 - 07:21
  • Cisco Designated VIP,
    2017 IP Telephony
Can you send us the ff: logs
debug isdn q931
debug ephone state
Aaziz AMHAOUCH Wed, 04/16/2014 - 13:27
The problem is resolved using this two commands just in POTS Dial-peer :
 progress_ind alert enable 8
Could you try those commands
BR,
Aaziz
Gustavo Adolfo ... Wed, 04/16/2014 - 13:50
Aaziz,
IOS mark as Invalid input when i tried to use these commnds on POTS Dial-peer, but in VOIP (NO MY CASE) I can use them.
Regards.
Gustavo Adolfo ... Wed, 04/16/2014 - 13:52
Ayodeji,
IOS mark as invalid input *debug isdn q931*. I'm using Controller E1.
BR
Tavo
