Warning message
5508 upgrade/backup controller
Answered Question
Apr 8th, 2014
  • Bronze, 100 points or more
Correct Answer by Leo Laohoo about 3 years 4 months ago
Old WLC = WLC1
New WLC = WLC2
Here's a proven process:
1.  Configure WLC2:  Make sure WLC2 has the same firmware as WLC1.  Copy the config of WLC1 to a notepad.  Change the IP addresses.  Copy the new config to WLC2.
2.  Upgrade the firmware of WLC2 (including the FUS/bootstrap).
3.  Make sure you configure DNS for WLC2.
4.  Connect WLC2 to the network and make sure you can remotely access WLC2.
5.  Upgrade the firmware of WLC1 but DO NOT reboot.
6.  Pre-download the AP images.
7.  Move the APs from WLC1 to WLC2.
8.  Once the APs have moved to WLC2, reboot WLC1.
Correct Answer by ISHANT VARSHNEY about 3 years 4 months ago
If I am concerned about minimizing downtime I would use AP image pre- download option.
>> I will download 7.6 image on old WLC and push this image to the APs connected to them. When Pre download is completed APs will have primary and secondary image as 7.0 and 7.6 . At this time both my APs and WLC are working with 7.0 image.
>> Swap the image on APs.
>> Check if we have right image on APs( show ap image all).
>> Now in downtime reboot the controller. APs will right away join with 7.6 image(this will save time what APs take to search for new WLC, download the code and then reboot and join the WLC).
>> Once the APs have joined the old WLC on 7.6 then we can move the APs to new WLC using HA tab.
Link : http://www.my80211.com/cisco-wlc-cli-commands/2011/2/20/wlc-predownload-...
I hope that helps.
Ishant
*** Please rate if you find it useful ***
Overall Rating: 5 (3 ratings)
Correct Answer
ISHANT VARSHNEY Tue, 04/08/2014 - 20:27
  • Cisco Employee,
I hope that helps.
Ishant
Correct Answer
Leo Laohoo Tue, 04/08/2014 - 21:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Old WLC = WLC1
New WLC = WLC2
lcaruso Wed, 04/09/2014 - 12:33
WLC2 has already been upgraded.
Leo Laohoo Wed, 04/09/2014 - 15:23
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for taking the time to rate our posts.
laugh
Abhishek Abhishek Fri, 04/11/2014 - 13:33
  • Gold, 750 points or more
Upgrade Process
    (Cisco Controller) >transfer download datatype code
    (Cisco Controller) >transfer download mode tftp
    (Cisco Controller) >transfer download serverip 192.168.44.248
    (Cisco Controller) >transfer download path /
    (Cisco Controller) >transfer download filename AIR-CT5500-LDPE-K9-7-5-102-0.aes
    (Cisco Controller) >debug transfer tftp enable
    (Cisco Controller) >transfer download start
