Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929105members
1243162discussions
Community Activity
com.sun.jersey.api.client.ClientHandlerException
Hi ,need some help on this error message.The error was: A built-in element encountered an exception of typecom.sun.jersey.api.client.ClientHandlerException. The root cause was: com.sun.jersey.api.client.ClientHandlerException: java.net.SocketTimeoutE...
kavle by Level 1
  • 35 Views
  • 2 replies
cant wr or copy run start
hi all,before on this switch (nexus 7000) i could do a "wr" or "copy run start" no problem but now i get thiswr[########################################] 100%Configuration update aborted: request was abortedthanks,rob
CUCM HUNT GROUP AND INTERCOM CALLS
Hi to allMy question is very simpleIntercom working fine , but the issue is that you can call only one intercom phoneWhat is the requirement if i want to perform an intercom call to a multiple phonesDoes this work with Hunt group?Regards
Site-to-site vpn failover causing memory spike in spoke sites
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
PikaPika by Level 1
  • 162 Views
  • 10 replies
Resolved! event syslog pattern syntax doesn't work
Hello,The DISA STIG, V-239941, asks that the following be configured:event manager applet BACKUP_CONFIG event syslog pattern "SYSLOG_CONFIG_I" action 1 cli command "copy startup-config scp://userx:xxxxxxx@10.1.48.10//opt/config_backup" action 2 syslo...
ASA SSL Certificate Trustpoint
Bonjour, Il y a quelques semaines, j'ai rencontré un problème sur plusieurs pare-feux ASA. Le système de monitoring envoyait des alarmes concernant le certificat de capteur SSL « Warning due to lookup value “No” in channel “Trusted root certification...
MJ666 by Level 1
  • 10 Views
  • 0 replies
Resolved! No SSL trust-points configured
Working on VPN and we are getting errors stating no TP found.  Did a sh ssl/ sh run ssl and got weird information back but need help with understanding TP's
Does XDR replace SIEM and SOAR?
Extended Detection and Response (XDR) - Versus - Security information and event management (SIEM). After the acquisition of Splunk as a SIEM and the launch of Cisco XDR, which one is better for detection and response?
Meddane by VIP
  • 62 Views
  • 1 replies
Multicast Lab Auto-RP
Hi ALL,I have setup a lab in CML for testing multicast using Auto-RP but I cant see traffic flowing from the source to the receivers . I can see the (S,G) entry in the first hop router and the (*,G) entry in the RP .Appreciate any feedback Thanks,Fra...
