I would use SOAP UI and Wireshark to attempt to some test calls and see what is actually going across the wire and see if there is a difference in what CPO sends versus what you can send via SOAP UI(or some other REST client)
Are you using OOTB IAC processes/activities or are you developing these yourself?
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
