04-09-2014 10:37 AM - edited 03-11-2019 09:03 PM
Hi All,
I don't have much information on ASA's but now i want to learn as much possible as i can.
I have an ASA5510 on which i can practice..............but first i have to do the software up-gradation from 7.0(6) to 8.2(5)
need some document to do this
Solved! Go to Solution.
04-09-2014 12:26 PM
Yes, you can do that.
Copy the new image onto the internal compact flash card (disk0:) and change (or add) a "boot system disk0:/<your image filename>" command in the config. "write mem" and "reload" and watch it boot (from console will show you the power-on self test and, in the event of any problem, give you an indicator of the issue encountered).
You should also copy over an updated ASDM image and set that as the image to use in the config. The latest ASDM (7.1(6)) is recommended and compatible with ASA 8.2(5)
04-09-2014 11:08 AM
Detailed steps are in the Configuration Guides section of the ASA Support page.
Specifically to go from 7.0(6) to 8.2(5), Cisco's supported path is described in the 8.2 release notes. They require you to first move to 7.1 and then 7.2 before coming the rest of the way in one final step up to 8.2(5).
If you don't care about migrating any current configuration, you could just blow away what you have and go straight to 8.2(5).
Hope this helps, please rate helpful posts.
04-09-2014 11:34 AM
04-09-2014 12:26 PM
04-10-2014 03:58 AM
I prefer to go to version 8.4 or above if you have it and you have enough DRAM on the ASA. This is because newer versions support object group and also the NAT syntax used are different than older version (pre 8.3).
Object group makes things easier for your to manage the configuration on the ASA. Here is a document where you can see the different, in terms of NAT, between older and newer version.
04-10-2014 05:27 AM
I agree that the newer code is better to learn on going forwards.
Since he was already running 7.0(6) (ca. August 2006) on the unit, one could assume that it was older - the ASA 5510 did not (by default) start shipping with the necessary 1 GB of DRAM required for 8.3+ until Feb 2010. (Reference)
