Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1915014members
1215759discussions
Community Activity
5/6GHz. One SSID to rule them all, or separate?
So, this is more a question of what people are using or seeing. We will be replacing all our facilities this year and I plan to go Wi-Fi6E. I have tested having the SSID with mixed, but I have also heard separate doe to if a client shifts frequencies...
Can we directly upgrade C9200-48P from 17.03.03 to 17.09.04?
Hello, everyone. Our compnay is going to upgrade C9200 software. Can we directly upgrade C9200-48P from 17.03.03 to 17.09.04? 您好,最近相对公司的 C9200 交换机进行软件升级,目前交换机的软件版本是 17.03.03,可以直接升级到最新版本 17.09.04 吗?有没有需要注意的地方?
Bourne by Level 1
  • 20 Views
  • 2 replies
Qatar @1-877-552-0621 Cancellation Policy
Title: How Do I Change My 헙헹헶헴헵혁 on 퐐퐚퐭퐚퐫 헔헶헿헹헶헻헲혀: A Comprehensive GuideIn the dynamic world of travel, plans can change at the drop of a hat. Whether it's a sudden change in schedule, an unexpected event, or simply a desire for flexibility, alterin...
ASIC speed difference
The overrun counter on the C9800 interface suggests that there might be a bottleneck in processing incoming traffic. Given that the facing switch is a C9500 with potentially different ASIC speeds, could the congestion and packet drops on the C9800 si...
wadwate3 by Level 1
  • 12 Views
  • 0 replies
integrate PCCE with C4C CRM system
hello alli was searching on how to integrate PCCE with C4C CRM system, and there were no documentation regarding this matter.i need to know what should be done from the PCCE side in order to route the calls to the CRM system and show the call informa...
WLC Guest Auth
Hello,What should we do if sometime the web auth for guest WLAN is not showing?
hs08 by Spotlight
  • 123 Views
  • 1 replies
Webex Desktop App Conference call issue
Hello, We recently noticed that when we try to create a conference call (internally) on Webex Desktop App, there is an issue adding a person using/searching their name (the button to call/add them to the conference call becomes unclickable). For exam...
pkyrou by Level 1
  • 18 Views
  • 0 replies
Resolved! Negative filter for Webhooks
Query form Jeremy Hall@charter.com on #webex4devs space: Is there a way to specify a not condition in webhooks filter, for example not roomId=blah, to notify on all rooms except this one?
Rudrakshi by Cisco Employee
  • 413 Views
  • 3 replies
第1回 Webex Blog - Webex の技術サポートに日本語で問合せする時の情報まとめ
こんにちは!Webex の日本語サポート部門でテクニカルサポートを担当している佐藤です。 早速ですがコラボレーション製品でもブログボードが開設されました! Webex に関連する最新情報やお役立ち記事の紹介など、タイムリーな情報発信を行っていきたいと思いますのでぜひお付き合い頂ければと思います。 記念すべき第1回となる今回は Webex に関連した技術的サポートの問い合わせ窓口に関する情報をまとめました。Webex の製品やサービスの不具合・障害に関する内容など、日本語で問合せを行いたい場合の...
