HREAP configuraiton in Cisco 3850 switch and Cisco 5508 WLC
jubair151
dear team,
I am trying to configure HREAP option in CIsco 3850 switch and WLC 5508. I am not able  to get the HREAP option in the advance TAB of the WLAN tab. Kindly let me know whether I can configure HREAP option in Cisco 3850 switch and Cisco WLC 5508.
Jubair.S
7 Replies 7
luckymike33
yes - you need to do the following:
Under wireless tab on the WLC, select the AP yu want to configure as H-REAP mode, then under the APs general tab. Choose AP Mode., and configure this to H-REAP mode.
Beware you will also need to modify the switch port that the AP is connected to must be changed to a trunkport, i.e. switchport mode trunk.
Here is a link for more detail.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/71250-h-reap-design-deploy.html
Mike
dear Mike,
I am using Cisco 3850 switch to register my access point. After Joining the access point, i was checking the option int AP settting to make it as HREAP, but i am not getting that option. Please find the attached screenshot.
3850/5760 (or Converged Access) does not support H-REAP or any other modes other than LOCAL mode AP deployment
See below for WLC feature comparison
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~controllers
Rasika
*** Pls rate all useful responses ****
Hi Rasika,
What about Cisco 5508. I am using Cisco AP 1600 and 3600 for this HREAP use. Am I able to configure HREAP in Cisco 5508 along with Cisco AP 1602 and 3600 series.
This is a good design and deployment guide for H-reap in 5508 .
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81680-hreap-modes.html
As per the Cisco documents, HREAP has been migrated as flex connect mode.
http://www.xerunetworks.com/2012/05/cisco-5508-wlc-configuration-lab-wpa2-guest-access-flexconnect-aka-hreap/comment-page-1/#comments
That all depends on the version of code that is running on the controller, I started off with HREAP on our 5508 because I was running a 7.0.x.x version once I moved to 7.4 HREAP was converted to flex connect...
