Banner template
Answered Question
Apr 10th, 2014
I have created templates but having an issue with the banner template I created - receiving the following error;
Error: Failsafe timeout while talking to device...
Could it be because the banner is roughly 30+ lines ?
Correct Answer by AFROJ AHMAD about 3 years 4 months ago
I think it is not there..
check it under ..design > feature and technology > security..
If you found any similar templete that you are interested then "save it as new template " and modify it according to your needs.
Thanks-
Afroz
Hi ,
Edit your template  and run the Banner as below ::
<MLTCMD>banner login ~  THIS IS A BANNER TEST
~</MLTCMD>
Thanks-
Afroz
***Ratings Encourages Contributors ***
Overall Rating: 5 (2 ratings)
Correct Answer
AFROJ AHMAD Thu, 04/10/2014 - 20:20
  • Cisco Employee,
Hi ,
~</MLTCMD>
Thanks-
Afroz
SpongeRob Fri, 04/11/2014 - 07:34
Thanks Afroz - I have been creating my own for DISA compliancy and was attemptimg to do the same here.  Lesson being - if there is a template use it ?
Correct Answer
AFROJ AHMAD Fri, 04/11/2014 - 09:47
  • Cisco Employee,
Thanks-
Afroz
