Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927516members
1240279discussions
Community Activity
Installing Secure Client (5.x) AND Any Connect (4.x) on 1 computer
I have a weird situation I need to connect to two sepaate VPN (not at the same time).One of these requires Cisco Secure Client 5.x the second works with Any Connect 4.x.I have Cisco Secure Client 5.x installed, if i try connecting to the VPN that use...
marcobat by Level 1
  • 87 Views
  • 1 replies
Setting UP a SECOND ASA5506-x firewall
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
Rebuild Cisco ACI with a new version
Hi, we have a Cisco ACI in our LAB enviroment with an older version 2.2. We'd like reset/clean all the fabric (n.3 APIC,n.2 Leaf and n.2 Spine) and restart with a new version, the 5.2. Our hardware support it We don't need the backup of actual config...
urbinir by Level 1
  • 0 Views
  • 0 replies
change Master Switch To slave in cisco Switch
Hello everyone, I have two cisco 3750 switches that are on stack with the below config Switch# Role Mac Address Priority State--------------------------------------------------------*3 Master 0017.5ae7.d500 1 Ready4 Member c062.6b8c.f200 1 Readyi wou...
joe5084 by Level 1
  • 6 Views
  • 0 replies
I cannot verify warranty expiration date on my 9200 switch
Hi guys,I'm trying to check the warranty expiration date of my 9200 switch, I just checked by SN on Device Coverage Checker (cisco.com) it says the warranty is covered but I cannot verify when the expiration date. How can I see when the expiration da...
yum3372 by Level 1
  • 74 Views
  • 4 replies
[Q&A 集公開] 4/17 開催 次世代の UCS X シリーズ - 新機能とトラブルシューティング
以下は 2024 年 4 月 17 日に開催した 次世代の UCS X シリーズ - 新機能とトラブルシューティング の Q&A セッションでいただいた質問とその回答となります。多数のご質問誠にありがとうございました。なお、当日の資料や録画は以下より確認可能です。 プレゼンテーション資料  ウェビナー録画  イベント概要    質問 1. 現在の初期導入時に UCSM 管理モード(UMM)ではなく Intersight 管理モード(IMM)を選択するメリットなどはございますでしょうか。I...
Eri Mizuno by Community Manager
  • 5 Views
  • 0 replies
Swithc oonfig
I am using a 3750 switch and going through a Sidewinder G2 firewall. Thefirewall only has its startup config on it with and Internal IP address (.1)which will be the internal gateway. My switch has VLAN2 config of .2. I can ping from my switch to the...
L3 Switches connecting to Firewalls
Hi All,I have a topology as shown below:The Firewalls A & B are running as active/standby. I have an etherchannel configured between L3 Switch A and Switch B. The switches also have HSRP running for various VLANs. The link between Switch and Firewall...
Ranjita by Level 1
  • 32 Views
  • 0 replies
  • 1 Helpful votes
NCS-5504 credentials loss
Hi Team,By mistake i have been deleted root credentials on my NCS-5504 XR . Now i am unable to login router. Any procedure how to recover the credentials.RegardsSalman+919871873874
Renewall of Admin Certificate
I have to renew the admin certificate in a pair of ISE nodes (Prim / Sec) on Version 3.2.0.542 Patch 4. Currently both devices have the same admin cert that expires in little over 3 weeks. All the names and IPs in this thread are placeholders. I gene...
Sergio C by Level 1
  • 51 Views
  • 1 replies
