RTSP streaming terminating prematurely
Apr 10th, 2014
We are requesting RTSP streams from MediaSense (audio is being forked by the CM  BiB method). The streams terminate after 120 seconds.
We are sending a request for an RTSP stream and receiving the stream for 120 seconds, at which point the stream suddenly stops. Since in the response to the initial play request we get “timeout=120” this appears to be an issue with the session timing out. We have tried sending both Play and Options messages for the same session  prior to the 120 seconds in order to prevent the session from timing out, but this has not worked.
Example pcap trace
Highlighted in yellow = Coming from Uptivity   Highlighted in green = Coming from Mediasense
OPTIONS rtsp://10.105.30.196/eca1454785bdad1 RTSP/1.0
CSeq: 1
User-Agent: CC_RTSP_Client
Authorization: Basic Y3RpdXNlcjpjdGl1c2Vy
RTSP/1.0 200 OK
Server: Cisco MediaSense Media Server
CSeq: 1
Public: DESCRIBE, PLAY, SETUP, SET_PARAMETER, GET_PARAMETER, TEARDOWN, PAUSE, RECORD, OPTIONS
DESCRIBE rtsp://10.105.30.196/eca1454785bdad1 RTSP/1.0
CSeq: 2
Accept: application/sdp
Accept-Language: en-US
RTSP/1.0 302 Moved Temporarily
CSeq: 2
Location: rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064633^d0ab401d956c9fd0ae23ec7e8c1915f49cb6e9e8
DESCRIBE rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 3
        RTSP/1.0 200 OK
CSeq: 3
Content-Base: rtsp://10.105.30.196:9554/eca1454785bdad1/
Content-Type: application/sdp
Content-Length: 743
v=0
o=- 15487880279310217208 15487880279310217808 IN IP4 10.105.30.196
s=Cisco Live Media Streaming Session
e=NONE
c=IN IP4 10.105.30.196
u=rtsp://10.105.30.196:9554/eca1454785bdad1
t=0 0
a=control:rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
m=audio 0 RTP/AVP 0 13
a=range:npt=now-
b=AS:8000
a=control:rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122?token=eca145478...^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
a=range:npt=now-
b=AS:8000
a=control:rtsp://10.105.30.196:9554/Pool_Device_123/Audio_Pool_123?token=eca145478...^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
SETUP rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122?token=eca145478...^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 4
Transport: RTP/AVP;unicast;client_port=6970-6971
x-retransmit: our-retransmit
x-dynamic-rate: 1
x-transport-options: late-tolerance=2.900000
RTSP/1.0 200 OK
CSeq: 4
Session: 747595639;timeout=120
Transport: RTP/AVP;unicast;client_port=6970-6971;server_port=24576-24577;mode="PLAY";ssrc=516173345
SETUP rtsp://10.105.30.196:9554/Pool_Device_123/Audio_Pool_123?token=eca145478...^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 5
Transport: RTP/AVP;unicast;client_port=6972-6973
Session: 747595639
x-dynamic-rate: 1
RTSP/1.0 200 OK
CSeq: 5
Transport: RTP/AVP;unicast;client_port=6972-6973;server_port=24578-24579;mode="PLAY";ssrc=516173346
PLAY rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 6
Session: 747595639
Range: npt=0.000000-
x-prebuffer: maxtime=2.000000
RTSP/1.0 200 OK
CSeq: 6
Session: 747595639
RTP-Info: url=rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122;seqno=61268,url...
Range: npt=0.00-
OPTIONS rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 7
Session: 747595639
RTSP/1.0 200 OK
CSeq: 7
Session: 747595639
Public: DESCRIBE, SETUP, PLAY, PAUSE, TEARDOWN, PAUSE, GET_PARAMETER, SET_PARAMETER, ANNOUNCE
TEARDOWN rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 10
Session: 747595639
RTSP/1.0 454 Session Not Found (Session <747595639> not found)
CSeq: 10
Session: 747595639
