04-11-2014 12:13 PM - edited 03-16-2019 10:27 PM
We have 9971 phones in our envirronment, and notice that the forward all option is not there. In another cluster that option is there as a softkey. Is there anywhere this feature needs to be enabled?
A.K.
Solved! Go to Solution.
04-11-2014 05:08 PM
I would check the feature control policy assigned to the phone and see if its disabled there.
04-12-2014 07:14 PM
What firmware revision are the phones running? There was a version that I've come across before where the button was missing as well, and a simple firmware update just for that model fixed the issue.
04-11-2014 05:08 PM
04-29-2014 10:44 PM
Thanks for the replies.
I am running the most current firmware available, sip9971.9-4-1-9. I also checked the feature control policy and the feature was not enabled.
Thanks George ! !
AK
04-12-2014 07:14 PM
