04-12-2014 06:17 AM
I want to get inputs from the users .
I want to display a form were user can select a input from drop down list.
That selected item i want to store it in a variable and use across the flow.
How to do that using create input request or is there any other way to do that.
Solved! Go to Solution.
04-12-2014 08:13 AM
You should be using "Input Request" to do what you are trying to do.
04-12-2014 08:13 AM
04-12-2014 08:43 AM
Thanks for your reply.
It really helped a lot
