C892FSP-K9 VPN? - SOLVED
adelium904
I bought a few weeks ago two C892FSP-K9.
When I bought it, I said it was to link 2 to 3 sites all together throught VPN site-to-Site. Those devices can have up to 50 VPN tunnel. I am not shure yet how to implement the ipsec tunnel vpn capability, but I am not sure that I have all the settings available.
Here is what I mean and the result of the "crypto ?" command:
(config)#crypto ?
  key                 Long term key operations
  pki                  Public Key components
  provisioning  Secure Device Provisioning
  wui                 Crypto HTTP configuration interfaces
In this list of available commande, I do not have
isakmp
In all the exemple I found in Internet to make a tunnel, they use isakmp. So if it is not avalable, How can I do?
By the way, do I have to do, activate something somewhere to have access to isakmp?
Thanks?
5 Replies 5
johnlloyd_13
Level 9
Level 9
Nowadays, Cisco sells a separate security license (PAK) for ISR G2 routers.
Try to issue a 'show version' to see if there's a permanent security license installed. If it says none (under security), then you'll have to order.
Thanks for the answer.
Show vertion gives me this.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C892FSP-K9 (revision 1.0) with 488524K/35763K bytes of memory.
Processor board ID FCZ1803C202
10 Gigabit Ethernet interfaces
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        C892FSP-K9            ************
License Information for 'c800'
    License Level: advipservices_npe   Type: Permanent
    Next reboot license Level: advipservices_npe
It should be Here?
You'll see it under UDI info and right before the config-register.
It look something like this:
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
i recently installed a security license key on one of our 2911 to establish an IPsec VPN tunnel.
hope this link might help:
http://wannabelab.blogspot.com/2014/04/using-cisco-router-as-tftp-server.html
I have contacted my reseler who tells me that the VPN for 50 tunnels comes with the device.
Look at the attached picture.
I have look in many different website an see that to do a vpn site to site link, I need this command "isakmp".
Is there another way to do it with either:
Vandman
I have found the solution. It seems that my devices were shiped with this IOS:
c800-universalk9_npe-mz.SPA.153-2.T.bin
I did not have the equivalent of advsecurity feature in it.
So Someone from Cisco send me this IOS:
c800-universalk9-mz.SPA.152-4.M6.bin
And all came back to normal... Now I have this:
(config)#crypto ?
  batch         Crypto Batch Processing
  call          Configure Crypto Call Admission Control
  ctcp          Configure cTCP encapsulation
  dynamic-map   Specify a dynamic crypto map template
  engine        Enter a crypto engine configurable menu
  gdoi          Configure GDOI policy
  identity      Enter a crypto identity list
  ikev2         Configure IKEv2 Options
  ipsec         Configure IPSEC policy
  isakmp        Configure ISAKMP policy
  keyring       Key ring commands
  logging       logging messages
  map           Enter a crypto map
  mib           Configure Crypto-related MIB Parameters
  vpn           Configure crypto vpn commands
  xauth         X-Auth parameters
Thanks For those who tried to help me.
Vandman
