WiFi Devices not connecting to WLC 4402
bibimohan
Hi All,
I have a WLC 4402 running on s/w version 7.0.240.0. Currently devices are reluctant to join the controller.
I am getting continuous log shown below
 %DHCP-3-SEND_OFFER_FAIL,
%DOT1X-3-MAX_EAPOL_KEY_RETRANS:
and  Decrypt errors occurred for client
Could't find a proper solution anywhere. Pls suggest...
Scott Fella
Need more info than that... can you post your show wlan <wlan id>
Make sure that if your using WPA, that you only either use WPA/TKIP or WPA2/AES, not both or a mix of one or the other.
-Scott
