Warning message
what IOS-based AP for AIR-ANT2410Y-R (Bridge between two buildings)
Apr 14th, 2014
We need to connect two buildings with wlan. Due to the environment we will use AIR-ANT2410Y-R Yagi Antenna. What actual AP (IOS-based) supports this antenna. Is the AIR-SAP2602... the right choice? And how to configure the AP with only one antenna-cable (the 2602 has 4 connectors)
Moin Ilyas Fri, 09/12/2014 - 14:45
  • Bronze, 100 points or more
System Requirements for AIR-ANT2410Y-R
This antenna is designed for use with Cisco Aironet access points and bridges but can be used with any 2.4-GHz Cisco Aironet radio device that uses an RP-TNC connector.
