AAA server precedence
I have two AAA servers configured in Global config, in the WLAN and in FlexConnect groups. If I understand correctly the AAA server in the WLAN has precedence over the others. Is this true? Does that mean that I can remove the AAA server config from the other two?
The AAA servers are used for 802.1x user authentication.
Philip
Scott Fella
AAA in the WLAN is used first... if you have network user also checked on the AAA server and for example you have a total of 4 AAA servers, 2 defined on your WLAN and two defined globally also maybe for another WLC, then when the two in the WLAN is marked as down, then the WLC will use your global AAA servers.  I don't check the box for network user or management in the AAA server, but define it in the WLAN.
-Scott
But when is the AAA servers in the FlexConnect group used?
