Warning message
ACL with Inter Vlan
Apr 14th, 2014
We are used Cisco 3750 Layer 3 Switch and linksys switch at Layer 2 level.
We are used total 10 VLAN,  We want block all inter-vlan communication,  So no body can access inter vlan .
All vlan can access server vlan
Dinesh Chavan
luckymike33 Mon, 04/14/2014 - 04:28
  • Bronze, 100 points or more
Can you explain a bit more about what the problem is that you are having?
Very best wishes
Mike
Richard Burts Mon, 04/14/2014 - 06:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dinesh Chavan
Based on what you have told us one solution would be to configure an access list for each of the SVIs on your 3750 switch and apply it on the inbound direction for the interface. In the access list you would permit packets with source address in the vlan of that interface a destination of the server vlan. You would deny all other traffic. This would allow each vlan to communicate with the server vlan but not with any other vlan.
Rick
