04-15-2014 01:36 AM
Hi All,
How to parse the standard output from script task in CPO.
Do we have any activity to parse the outputs ??
Solved! Go to Solution.
04-15-2014 07:29 AM
As I outlined in https://supportforums.cisco.com/discussion/12172506/how-get-variable-script-cpo the means for parsing the output will depend on the output format and what you are trying to achieve.
The tools/activities to use could range from
04-15-2014 07:29 AM
