QoS on dialer interface with MLPPP
Apr 15th, 2014
I am facing a curious situation at applying CBWFQ on dialer interface with MLPPP.
Platform is Cisco2901 and IOS version is 15.3(3)M1
If I applied "service-policy output WAN-CBWFQ" on dialer interface with MLPPP, it is just discarded without any error message.
Policy-map and interface config is as follow.
policy-map WAN-CBWFQ
 class RT
  bandwidth percent 97
  queue-limit 128 packets
 class Data
  bandwidth percent 2
 class class-default
interface Dialer2
 ip address 172.26.156.1 255.255.255.252
 encapsulation ppp
 dialer pool 2
 dialer string 00000000   (00000000 is dummy)
 dialer load-threshold 1 either
 dialer-group 1
 ppp authentication chap
 ppp chap hostname golbasi_isdn
 ppp multilink
After several trial, I found following step (to remove "ppp multilink" before applying "service-policy") worked.
[config command]
conf t
int di2
no ppp multilink
service-policy output WAN-QOS-ISDN
ppp multilink
end
Interface config after above step is as follow.
interface Dialer2
 encapsulation ppp
 dialer pool 2
 dialer string
 dialer-group 1
 ppp multilink
I tried this on another IOS 15.2(4)M5, and it worked as expected just "service-policy" command without step to remove "ppp multilink".
Does this mean newer IOS (such as 15.3) does not support QoS on dialer interface with MLPPP ?
Best Regards,
