04-15-2014 05:04 AM - edited 03-16-2019 10:28 PM
We're trying to migrate all our DN's from E.164 to +E.164 on our CUCM 9.1.2SU1.
It seems that for the meetme patterns I cannot do this as it's saying I cannot use the +
Any help?
Jeroen
Solved! Go to Solution.
04-15-2014 06:31 AM
Hello Jeroen,
Tip | Meet-Me patterns, Call Park (and related call park features; for example, Directed Call Park) patterns, and Call Pickup patterns do not support the international escape character, +, so you cannot enter \+ in the pattern fields that are configured for these features. |
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010000.html#CUCM_RF_UAD8BE59_00
>> so you may need to configure the translation pattern for the meet-me number range to strip the + before hitting the numbers
//Suresh
Please rate all the help posts.
04-15-2014 06:32 AM
I believe this is the case, so you will need to define those without + sign. There may be others, for example CTI ports, contact center agent IDs, etc. SRND describes it and states to use translations.
Chris
04-15-2014 06:31 AM
Hello Jeroen,
//Suresh
04-15-2014 06:37 AM
Hi Guys,
OK, thanks for your help. Indeed it seems + or \+ is not supported.
I have done it with a translation pattern now so that is OK.
Jeroen
04-15-2014 06:32 AM
Chris
