Multicast PIM RP config
bryantsteve
I need to create  a IP PIM RP for a  specific multicast group to run on my local network. I want my edge router
(a c3750 Layer3 switch actually)  to be the RP for this group to serve a  small group of downstream c3750 Layer 3 switches.
Multicast is already configured on the network and works just fine in sparse mode using an RP
situated on an external network and is for all multicast groups
How do I need to configure the edge router for it to perform as the RP for a specific Mcast group, e.g. 226.0.0.0/8? Thanks
Bilal Nawaz
On all multicast enabled routers:
conf t
ip pim rp-address x.x.x.x 1
ip access-list standard 1
permit 226.0.0.0 0.255.255.255
Where x.x.x.x is the RP address for the group.
hth.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
