Warning message
ISE 1.2 patch 6 - All Authentications begin failing after about 20 minutes
Apr 15th, 2014
Hi all,
Another strange one I am throwing out to the forum. Basically I have a 5 node deployment (1 x Primary Admin, 1 x Primary Monitoring, 1 x Secondary Admin/Monitoring and 2 x Policy Nodes). The primary authentication method is EAP-TLS or PEAP for wireless only. The deployment in question has been in pilot for about 3 weeks with no issues what so ever.
As of this morning we rolled into production and all seemed well - about 100 users successfully authed against PSN1 (PSN2 is configured in the WLC as a secondary radius). About 30 minutes after the production rollout authentications began failing for the exact same reason (see attached radius log). I checked all of the certificates as recommended in the log but this was a matter of course in that everything is as it should be.
My next step was to essentially stop PSN1 (application stop ise) to see if the issue was a problem on the second PSN. All authentications were now succeeding via PSN2. I left it this way for 30 minutes with no drama. I started PSN1 again and authentications began to work....20 minutes later the issue was back. I replicated this issue again to be sure.
At this point I decided to deregister PSN1 and application reset the node before rejoining with the ISE deployment. Authentications worked well until about 30 minutes later when the issue reappeared. At this point I reloaded all nodes in the ISE deployment to see if this made a difference but the issue still remained.
Currently I have PSN1 shutdown and all is functioning well - anyone have any ideas??
Stephen McBride Mon, 04/28/2014 - 22:35
I got this fixed via TAC. Basically the following is the bug but it is worth noting that this deployment was a fresh build of 1.2
https://tools.cisco.com/bugsearch/bug/CSCuj17272/?reffering_site=dumpcr
Symptom:
all auth fails when using the existing identity source sequences after upgrade from 1.1.3 to 1.2.
Conditions:
upgrade from 1.1.3 to 1.2 build 899 breaks all auth using identity sequences.
Basically the fix was to recreate my ID sequences and reapply to the authentication policy. This fixed the issue on the policy node in question.
