Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929525members
1244125discussions
Community Activity
CMX - cmxadmin password recovery 11.0
I am following this document to recover and reset the password for "cmxadmin" https://www.cisco.com/c/en/us/td/docs/wireless/mse/11-0-1/cmx-config/b_cg_cmx1101/performing_administrative_tasks.html#id_131101 When I reset my VM Server and edit ("e") in...
IPSEC VPN
Hello Team,I have below topology : -I have ipsec vpn from on-prem to aws cloud. the two endpoints  [192.168.40.10/32, 192.168.30.10/32] work fine as they are allowed on the encryption domain.I have users using remote vpn to connect to on-prem dc to a...
fmugambi by Spotlight
  • 50 Views
  • 7 replies
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 106 Views
  • 4 replies
Multipod L3Out Preference
Hi All,I'm currently deploying ACI Multipod with two pods.I've configured a single VRF and single BGP L3Out that connects the leaf switches within each pod to our core network. This L3Out is then assigned to each BD which results in the the associate...
dm2020 by Level 1
  • 157 Views
  • 3 replies
CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 90 Views
  • 5 replies
cannot get to privileged enable mode via console
After searching through other posts, my config seems OK but still strange behaviourasa 9.20 running on FPWR chasisI cannot get in enabled mode when connecting to ASA via console.It used to work but stopped after I played (disable and restore) with aa...
kewwa by Level 1
  • 118 Views
  • 5 replies
Repeating syslog Message and then Crash
We're seeing a continuous string of the following messages on a 9407 running 17.9.5.  Eventually the switch crashes.  I can't find any info on what these messages mean exactly and whether we're looking at a software or hardware fault.  The supervisor...
Cisco Table Microphone Pro LAN connection?
I've went through the available documentation of the new Cisco Table Microphone Pro but I could not find if the microphone UTP/LAN cable can be connected to the same LAN of the Room codec or if it needs to be connected to the private LAN of the codec...
gfolens by Level 4
  • 56 Views
  • 1 replies
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 240 Views
  • 12 replies
Anyconnect Linux aarch64 (arm64) version?
Hello,While there are linux x86_64 versions and Windows arm64 versions:https://cios.dhitechnical.com/Cisco_Firewall_ASA_FTD/Anyconnect%204.x/anyconnect-all-packages-4.10.08029-k9/are there any plans to release a linux aarch64 (arm64) version?This wou...
bpietras by Level 1
  • 21 Views
  • 1 replies
wireless authentication
hello I am working in an environment where there is a wireless guest infrastructure configured  guest users are given access by an Administrator based on their email  there is  a requirement for a wireless printer to be given access to this guest net...
Resolved! How can i match vsmart with each Tenant
Hello team Last day i upgraded all controller  in to 20.3.5 -> 20.6.5 version as you know in 20.3.5 which use  multitenant mode , the vsmart are bind in each tenant. but when i upgarde it 20.6.5 version. the vsmart are come out side. I want to use th...
