04-16-2014 03:09 AM - edited 03-11-2019 09:05 PM
I'm trying tu publish my Polycom codec outside, and i did for this purpose static NAT according asa docs.
interface Ethernet0/0
nameif Outside
security-level 0
ip address X.X.40.98 255.255.255.240
object network HDX6000-INT
host 192.168.42.33
object network HDX6000-EXT
host X.X.140.100
access-list outside-in extended permit ip any object HDX6000-INT
nat (Inside,Outside) source static HDX6000-INT HDX6000-EXT
and it don't works anyway.
Packet trace is ok.
# packet-tracer input Outside tcp 8.8.8.8 1720 X.X.140.100 1720 $
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Additional Information:
NAT divert to egress interface Inside
Untranslate X.X.140.100/1720 to 192.168.42.33/1720
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 0.0.0.0 0.0.0.0 Outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside-in in interface Outside
Forward Flow based lookup yields rule:
in id=0xaebaa948, priority=13, domain=permit, deny=false
hits=2, user_data=0xaa86a3c0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0
dst ip/id=192.168.42.33, mask=255.255.255.255, port=0, dscp=0x0
input_ifc=Outside, output_ifc=any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0xad774470, priority=0, domain=inspect-ip-options, deny=true
hits=9183193, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 5
Type: INSPECT
Subtype: inspect-h323
Result: ALLOW
Config:
class-map botnet-class
match default-inspection-traffic
policy-map botnet-policy
class botnet-class
inspect h323 h225 _default_h323_map
service-policy botnet-policy interface Outside
in id=0xae2d4e08, priority=72, domain=inspect-h323, deny=false
hits=7, user_data=0xae2d3e30, cs_id=0x0, use_real_addr, flags=0x0, protocol=6
dst ip/id=0.0.0.0, mask=0.0.0.0, port=1720, dscp=0x0
Phase: 6
Type:
Subtype:
Result: ALLOW
Config:
in id=0xae2ce448, priority=18, domain=flow-export, deny=false
hits=1321269, user_data=0xae2a1ef0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
in id=0xae1c10f8, priority=13, domain=ipsec-tunnel-flow, deny=true
hits=49347, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type:
Subtype:
Result: ALLOW
Config:
in id=0xae1f7aa0, priority=13, domain=dynamic-filter, deny=true
hits=66109, user_data=0xae1f7378, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
dst ip/id=192.168.0.0, mask=255.255.0.0, port=0, dscp=0x0
Phase: 9
Type:
Subtype:
Result: ALLOW
Config:
in id=0xae1f9460, priority=12, domain=UNKNOWN:49, deny=false
hits=85104, user_data=0xae1f9420, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
out id=0xaec80db8, priority=6, domain=nat-reverse, deny=false
hits=1, user_data=0xae9df740, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
input_ifc=Outside, output_ifc=Inside
Phase: 11
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in id=0xad799030, priority=0, domain=inspect-ip-options, deny=true
hits=9773422, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
input_ifc=Inside, output_ifc=any
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10477792, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_punt <H225 connection inspection>
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: Outside
input-status: up
input-line-status: up
output-interface: Inside
output-status: up
output-line-status: up
Action: allow
#show xlate
1724 in use, 3679 most used
Flags: D - DNS, i - dynamic, r - portmap, s - static, I - identity, T - twice
NAT from Inside:0.0.0.0/0 to Outside:0.0.0.0/0
flags sI idle 0:01:19 timeout 0:00:00
NAT from Inside:192.168.42.33 to Outside:X.X.140.100
flags s idle 0:02:18 timeout 0:00:00
Did i miss something?
04-16-2014 03:43 AM
Hi, can you post the output of show route command?
Your Outside IP address is X.X.40.98 255.255.255.240 and you are NATing the internal HDX to X.X.140.100. Is your ISP routing all traffic destined to .140.100 to .40.98? I mean is the .140.100 is visible to the Internet? The reason I'm asking this is because normally you will do a static NAT to an extra pub IP that is on the same subnet as your Outside IP address unless your ISP routes it.
Regarding why the packet tracer works is because the ASA is assuming the packet from 8.8.8.8 can reach the Outside interface of ASA.
04-16-2014 04:29 AM
Gateway of last resort is X.X.140.97 to network 0.0.0.0
O 192.168.46.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.62.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.47.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
S 192.168.44.6 255.255.255.255 [1/0] via X.X.140.97, Outside
S 192.168.44.9 255.255.255.255 [1/0] via X.X.140.97, Outside
O 192.168.45.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.42.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.58.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:27, Inside
O 192.168.40.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.57.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:27, Inside
O 172.16.252.0 255.255.255.252 [110/11] via 192.168.5.1, 29:08:27, Inside
O 172.16.251.0 255.255.255.252 [110/511] via 192.168.5.1, 29:08:27, Inside
O 172.16.32.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:27, Inside
O 172.16.31.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:27, Inside
O 192.168.56.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:28, Inside
O 192.168.41.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:28, Inside
O 192.168.55.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:28, Inside
C 192.168.5.0 255.255.255.248 is directly connected, Inside
O 10.189.151.0 255.255.255.252 [110/12] via 192.168.5.1, 29:08:28, Inside
O 192.168.6.0 255.255.255.248 [110/261] via 192.168.5.1, 29:08:28, Inside
O 192.168.233.233 255.255.255.255
C X.X.140.96 255.255.255.240 is directly connected, Outside
O 192.168.52.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:28, Inside
O 192.168.51.0 255.255.255.0 [110/12] via 192.168.5.1, 29:08:28, Inside
O 192.168.50.0 255.255.255.0 [110/61] via 192.168.5.1, 29:08:28, Inside
O 192.168.48.0 255.255.255.0 [110/11] via 192.168.5.1, 29:08:28, Inside
S* 0.0.0.0 0.0.0.0 [1/0] via X.X.140.97, Outside
O 192.168.32.0 255.255.252.0 [110/11] via 192.168.5.1, 29:08:28, Inside
# ping outside 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/16/20 ms
