NAC agent dont popup automaticaly at the first connexion
nicanor00
I have ISE 1.2 and catalyst 2960
But the NAC agent is not poping up automatically at the first conection on the network
All log and authentication session look OK but the NAC agent dont popup automatycaly
At the first conexion on the network I must right click on NAC properties and enter manualy the IP address of the ISE on the discovery host field before get the NAC popup
Then for the second and the other next conexion on the network, the NAC agent popup automaticaly, even if I remove the IP address of the ISE on the discovery host field
Why do I need to enter the IP of the ISE manualy before get the first NAC agent  popup ?
I need the NAC agent to popup automatycaly at the first conexion of the PC on the network (switch) without entered manually the IP address of the ISE on the discovery host field
Please help
Venkatesh Attuluri
check
Policy > Policy Elements > Results > Client Provisioning > Resources
edit the profile and there should be a discovery host box.
