Warning message
3745 crashing on boot
Answered Question
Apr 16th, 2014
  • Bronze, 100 points or more
So I was getting ready to list my old router (a fully loaded 3745, 512mb ram, 2x 128mb flash, 2x VPN-AIM's, a NM-1GE, dual powersupplies and dual inline powersupplies) on ebay so I figured I need to get a show ver so I need to boot it.
well first I cleaned all the dust out of it (been a few months since I upgraded to a 3845) and the 3745 had been working fine when I pulled it out and swapped it.
well now the 3745 is crashing on boot attached is the crash dump
it has the latest Rommon and latest IOS that were made for it
please help
Correct Answer by Leo Laohoo about 3 years 4 months ago
Eject all your network modules, particularly your Serial Interface card.
Crashinfo is saying that a "Serial0/0" is causing the crash.
Can you also make sure the DRAM is properly seated?
Overall Rating: 5 (3 ratings)
Correct Answer
Leo Laohoo Wed, 04/16/2014 - 22:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
is66rlhntadm Wed, 04/16/2014 - 22:19
Well thats an odd thing then.
on the first boot I has a T1 wic but I pulled it out and there was no change
I'll go pull the other flash card and see if it has a hopefully more useful crash dump
only other module is a NM-1GE
I'll pull that out. (though I hope that's not the cause)
Leo Laohoo Wed, 04/16/2014 - 22:22
  • Hall of Fame,
    2017 LAN, Wireless
CPU signal 22
By the way, this error message does NOT bode well.  It normally means it's a hardware fault.
is66rlhntadm Wed, 04/16/2014 - 22:26
Well I do have a spare MB, though that might hurt the intended sale (was planning to sale the following
1x Fully loaded 3745 (as mentioned above)
1x Powersupplyless 3745 (spare parts)
1x 2651
and 2x 2924M-XL
ok heres another crash dump
I think its a diff one but a little unsure as with the clock not set the time stamps all match, so I've now cleared the dumps from teh CF cards and will give it another try in a min
is66rlhntadm Wed, 04/16/2014 - 22:35
well pulled the NM-1GE and it booted
thought deleting the config from the CF cards has erased the config but still had to do write erase
Going to try putting the NM-1GE back in
is66rlhntadm Wed, 04/16/2014 - 22:43
Ok re inserted the NM-1GE and its still working
guess maybe it was a little loose or something.
is66rlhntadm Wed, 04/16/2014 - 22:47
Thanks for the help (I think I'm going to toss the T1 card, it came with my 3845 but I never had a use for it just though I'd toss it with the 3745 as a little extra)
btw heres the sh ver
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(25d),
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 08:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c3745-adventerprisek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
[email protected].
Cisco 3745 (R7000) processor (revision 2.0) with 499712K/18432K bytes of memory.
Processor board ID JMX0809L3LB
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
125952K bytes of ATA Slot0 CompactFlash (Read/Write)
Configuration register is 0x101
Router#
Leo Laohoo Thu, 04/17/2014 - 00:41
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for taking the time to rate our posts.
I'm happy to see you've got the router going.  NM-1GE, wow.  I've never seen that model for a long, long time.  Should've donated it to the museum.
That and the 2924M.
is66rlhntadm Thu, 04/17/2014 - 01:09
Well I had gotten the NM-1GE back when I upgraded to a docsis3 modem I also had 3x NME-16ES-1G-P's in it when I used it (I've since moved the etherswitches to my 3845)
really wish cisco had a Docsis3 Hwic, even if only to have some SNMP monitoring of the RF stats (currently I have a web page that scrapes the RF stats off the modem so that PRTG can fetch the data in a format it likes)
so the NM-1GE gave the 3745 a gig link to the modem and the NME-16ES-1G-P did intervlan routing and a gig link to my 2960G
