Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926302members
1238014discussions
Community Activity
Call Center Call Logs
Interested in retrieving call center agents' call log details.Used the below url https://xsi.nextiva.com/com.broadsoft.xsi-actions/v2.0/user/clusterx.kavi/directories/CallLogs/received/?startTime=2024-04-01T01:00:00 This one returns the received call...
Bryni by Level 1
  • 0 Views
  • 0 replies
L2VPN Over GRE
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
Testing
This is a test post kindly ignore it. Happy journey  from delta represen.
Serial number vManage
Hi, I have to pass the serial to the tac, use this command in vManage, is this the correct information or does anyone remember which command by cli, catalyst manager or both I can collect this information. Thank you very much for your help Regards....
Resolved! Can FMC running in vsphere be migrated to AWS?
I plan to migrate a FMC running in vsphere to AWS. Initially I plan to: 1. Build the FMC in AWS as brand new; 2. Backup the existing FMC (running v7 already) and then restore the backup in AWS FMC; 3. Login to AWS FMC serial console to change the MGM...
m1xed0s by Spotlight
  • 4581 Views
  • 21 replies
ISE Cert Question
HiDo I need to generate a CSR for a cert on ISE its a *cert or can I just add the cert to the ISE Nodes for Portal use.?? Thanks
Cisco Secure Client XML overwrite issue
Hello, any help appreciated.I am having issues when trying to assign a different group policy to a user where the group policy contains a different client profile (XML) to the one used to connect in the first instance. This is what I am trying to do....
9800-40
Hi Is there any document that shows that WLC 9800-40 support wifi-6 and 6G band! I cant find that document
Moudar by VIP
  • 76 Views
  • 6 replies
VRRP issue
Facing issue with VRRP, when upstream router5 initiate traffic for downstream router6 then return traffic is not following VRRP VIP as Gateway. In my case switch2 is master and switch3 is standby.If Router6 initiate the traffic then VRRP working fine...
Resolved! ISE admin Group AD users
I have created an external admin group in ISE, which is pointing to an AD group. There are several users in this AD group.Will all the users in this AD group gets ISE admin access or can it be restricted to few users.
manvik by Level 3
  • 282 Views
  • 8 replies
Umbrella and Canon Uniflow
We are moving from Zscaler to Umbrella and use Canon Uniflow for the printers.The printers worked fine before Umbrella but can not print anymore since moving to Umbrella.There is only default policy enabled for the tunnels from sdwan routers to Umbre...
likvid by Level 1
  • 106 Views
  • 4 replies
Internal Transfer Calls for Courtesy Call Back
Hello All,  I am trying to make CCB call for internal calls. But calls are failing at callback entry application with below error. CallbackEntry,04/05/2024 12:27:40.868,Validate_01,custom,Callback_Validate,ELEMENT_ENTRYCallbackEntry,04/05/2024 12:27:...
