Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919290members
1223467discussions
Community Activity
Anyone help me with this topology
1. Make end to end connectivity first. 2. Block the network for these site   1)Make sure that Site 4 will not advirtise any network to Site 5 which it receiving from Site3 routers.  2) On site 5 , when we check routing table of R2 router,  it dont ha...
What is the purpose of this equipment..Senior artists
A = cisco N9K-C9504This is a tool that was included in the equipment packaging box while mounting the equipment A. What is this tool used for? It looks like earwax, so my grandmother covets it. Please advise quickly. Thank you, mastersPlease understa...
seedmon by Level 1
  • 19 Views
  • 0 replies
Dhcp server with vlan's
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 80 Views
  • 1 replies
VRF Leak Configuration
        VRF Route LeakAs already we know that, Virtual Routing and Forwarding (VRF) is a technology for creating separate virtual routers on a single physical router. Ro...
Gopinath_Pigili_0-1711683498667.png Gopinath_Pigili_2-1711683525711.png Gopinath_Pigili_3-1711683877641.png Gopinath_Pigili_4-1711683925500.png
Ruckus 7150 to Cisco 3750 trunk port not working
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 159 Views
  • 4 replies
Cant make call from jabber api - jabber web sdk
Hi team, is anyone out there very familiar with the Jabber Web SDK? I don't understand much about this and we have a situation here where we are using the Jabber Web SDK and the firefox extension, we see that our aopi registers with the call manager ...
csrlima by Level 3
  • 377 Views
  • 2 replies
Resolved! DNA Center integration with DNA Spaces
Hi all,I'm integrating DNA Center with DNA Spaces and the DNA Spaces was successful, however, when attempting to sync Map Hierarchy with DNA spaces , specifically Area ( Design > Network Hierarchy > (Select Area ) > Sync : DNA Spaces/CMX ) an error p...
CBS350-24P-4X Rackmount disalignment
Hi community,I'm a bit confused...I recently got a CBS350-24P-4X 1U managed switch, which comes with a wall-mount/rack-mount (I guess?) kit and I'm wondering, how I could manage to install this kit onto the device in order to align the rackmount-ears...
CBW151AXM not connecting to CBW150AX (Red, green, black led)
First off, I have to say I am EXTREMELY dissatisfied with Cisco's supposed support.  I just bought this device and it is not connecting.  I did the usual google searches and nothing helps.  I watched the Tech Talk videos and followed the directions w...
Is ACI to replace this design?
Assume I have to routing among different block of campus network with a square cross connected with OSPF peer to peer type,what is the disadvantage of this square cross design?Is ACI fabric used to replace this square cross design? or replace campus ...
Maivakov by Level 1
  • 85 Views
  • 1 replies
[Intersight] 契約ステータスが"Not Covered"と表示される場合の対処について
はじめに症状サポート契約の確認対処     はじめに 本ドキュメントは、Intersight (SaaS, Virtual Appliance) において、ターゲットの契約ステータスが "Not Covered" と表示されている場合の対処方法について説明します。   症状 以下のように、ターゲット(サーバ、シャーシ、ファブリックインターコネクト etc.)の契約ステータスが "Not Covered" というクリティカルなステータスになっている場合、該当ターゲットのシリアル番号に対して...
how to modify TTL to less values at routers?
Assume that there are three router type devices outside firewall, and one core switch router behind one layer firewalland I would like to hide the router hop of core switch router from traceroute how to modify TTL to less values at router at the most...
Maivakov by Level 1
  • 101 Views
  • 3 replies
