Warning message
How many AP does 2504 Controller Supports
Answered Question
Apr 19th, 2014
I would like to know how many AP's does WLC 2504 supports? As per the data sheets it supports 75 AP then why is the part number is still AIR-CT2504-50-K9 (where 50 is AP?)
Thanks.
Shakeer.
Correct Answer by ISHANT VARSHNEY about 3 years 4 months ago
Hi Shakeer,
You are correct as per model AIR-CT2504-50-K9, 50 means that the maximum number of APs supported on this WLC is 50.
But, 7.4 WLC release increased scale on 2504 WLC. Previously, it could support max of 50 APs.
From the 7.4 WLC release notes:
"Increased scale for Cisco 2500 Series Controllers to support 75 access points and 1000 clients."
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74....
I suggest if you upgrade to 7.4 you will get the full AP count as expected.
HTH.
Ishant
*** Please rate the post if you find it useful ***
Overall Rating: 5 (1 ratings)
Correct Answer
ISHANT VARSHNEY Sat, 04/19/2014 - 10:32
  • Cisco Employee,
Hi Shakeer,
HTH.
Ishant
Scott Fella Sun, 04/20/2014 - 07:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The most important thing to look at when choosing the 2504 also is the max client count which is 1000.  Some customers require more than that and is forced to go with a 5508 instead.
