Network Drive and Vlan
Apr 19th, 2014
I am trying to setup multiple SSID's, each having their own vlan. When I access my Network Drive on the main Vlan, I am able to access my network drive. When I connect to the other SSID on their own vlan, I am unable to access the network drive. What could I do so I could access the network drives over more then one Vlan?
Michal Dulovic Mon, 12/01/2014 - 06:38
I am not familiar with this hardware  but general steps you can take:
Disable AP-isolation (ap isolation makes your wifi clients talk only with default gateway and then to internet, local lan is not reachable), probably not an issue as inter-vlan routing is done on GW but ...
Enable Inter-Vlan routing. (enables routing the packets from one vlan to another)
Check if there arent any "limitations" on the second wlan/ssid/vlan like some guest features etc..
Also remember when accessing the drive from the second wlan/ssid/vlan you are on different bcast domain (probably also different subnet) and so you wont see the the network drive as a result from some network discovery as broadcast originating from network drive will not reach you.
You have to manually statically point to the network drive address to reach it.
Related Content
