nat64 config on ism
asheesh.mamgain
Hi all,
need to know the Nat64 config on asr9k with iosxr4.3 . will be needing DNS64 as well what config in needed in serviceapp interface towards the ipv6 side. what will be needed in dns 64.
regards
asheesh
xthuijs
Hi Asheesh, we have some good ISM/CGN support forum documents available too. Not sure if they specifically list a nat64 config, so in the potential absence of that here you go:
•Configure CGN role, INFRA SVI as below.
For CGN role, serviceInfra should have a address mask of at least /30
conf t
int serviceInfra1
  ipv4 add 1.1.1.1/30
  service-location 0/2/cpu0
  commit
  exit
hw-module service cgn location 0/2/cpu0
commit
exit
NAT64 Configuration – V4 ServiceApp and Static Route
conf t
int serviceApp41
    service  cgn  cgn1 service-type nat64 Stateful
    ipv4 add 41.41.41.1/30
    commit
exit
router static
  address-family ipv4 unicast
  52.52.52.0/24 ServiceApp41 41.1.1.2
   commit
   exit
end
NAT64 Configuration - V6 ServiceApp and Static Route
conf t
int serviceApp61
    ipv6 address 2001:202::/32
    commit
exit
router static
  address-family ipv6 unicast
  3301:db8::/32 ServiceApp61 2001:202::2
  commit
  exit
end
service cgn cgn1
 service-location preferred-active 0/2/CPU0
  service-type nat64 stateful nat64_1
  ubit-reserved
  refresh-direction Outbound
  portlimit 65535
  ipv6-prefix 3301:db8::/32
  ipv4 address-pool 52.52.52.0/24
  ipv4 address-pool 53.53.53.0/24
  dynamic-port-range start 1
  tcp-policy
  filter-policy
  fragment-timeout 10
  address-family ipv4
   tos 125
   interface ServiceApp41
   tcp mss 900
  address-family ipv6
   interface ServiceApp61
   traffic-class 130
   tcp mss 750
service cgn cgn1
   protocol tcp
   address 40.1.1.2
    timeout 100
    port 500 timeout 70
   port 600 timeout 80
  external-logging netflow version 9
   server
    address 90.1.1.1 port 99
    session-logging
xander
