H.323 gateway not sending disconnect message
SAIFUDEEN C .K
Hi All,
I have configured a new E1 and associated DID range.
I am getting ring back for unallocated numbers.There is no matching pattern exist and debug showing unallocated number error.But still I can gett the ring back tone from PSTN.
It seems gateway is not sending the disconnect message.
Please help me how to check that.
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8483 - Origination address is non-ISDN
        Calling Party Number i = 0x00C3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '349509'
                Plan:ISDN, Type:National
        Low Layer Compat i = 0x9090A3
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8                                             001
Apr 21 11:49:32 BST: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x80                                             01
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Apr 21 11:49:35 BST: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x904                                             C
Apr 21 11:49:35 BST: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0                                             x104C
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
Sending Complete
Standard = CCITT
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349509
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4844FC14, Call Info(
   Calling Number=90,(Calling Name=)(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=9, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 21 10:51:25 BST: //-1/5623EE478B9D/CCAPI/ccCheckClipClir:
   In: Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable)
   Out: Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable)
Apr 21 10:51:25 BST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 21 10:51:25 BST: :cc_get_feature_vsa malloc success
Apr 21 10:51:25 BST:  cc_get_feature_vsa count is 11
Apr 21 10:51:25 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1207650424,feature_id:18228
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=90(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN))
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_process_call_setup_ind:
   Event=0x47FC45B0
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallSetContext:
   Context=0x48A646A4
   >>>>CCAPI handed cid 18228 with tag 9 to app "_ManagedAppProcess_Default"
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=349500, Params=0x48A6725C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCheckClipClir:
   Destination Pattern=349..., Called Number=349509, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=5623EE47-C871-11E3-8B9D-001EBE027FE0, Outgoing Dial-peer=349500
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349509
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x47D29438, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=90,(Calling Name=)(TON=National, NPI=Unknown, Screening=Network, Presentation=Unavailable),
   Called Number=349509(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=349500, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 21 10:51:25 BST:  cc_get_feature_vsa count is 12
Apr 21 10:51:25 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1207658416,feature_id:18229
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccCallSetContext:
   Context=0x48A6720C
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccSaveDialpeerTag:
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_call_proceeding:
   Interface=0x47D29438, Progress Indication=NULL(0)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_call_cut_progress:
   Interface=0x47D29438, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
   Call Entry(Responsed=TRUE)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=1
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=18228
Apr 21 10:51:25 BST: //18228/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45BEF84C, callID1=0x4734, callID2=0x4735, tag=0x0)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/ccConferenceCreate:
   Conference Id=0x45BEF84C, Call Id1=18228, Call Id2=18229, Tag=0x0
Apr 21 10:51:25 BST: //18228/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2105, Source Interface=0x4844FC14, Source Call Id=18228,
   Destination Call Id=18229, Disposition=0x0, Tag=0xFFFFFFFF
Apr 21 10:51:25 BST: //18229/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr 21 10:51:25 BST: cc_api_get_xcode_stream : 4381
Apr 21 10:51:25 BST: //18229/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2105, Source Interface=0x47D29438, Source Call Id=18229,
   Destination Call Id=18228, Disposition=0x0, Tag=0x0
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2105, Destination Call Id=18229)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2105, Destination Call Id=18228)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x47D29438, Destination Call Id=18229, Source Call Id=18228,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2105, Call Id1=18228, Call Id2=18229
Apr 21 10:51:25 BST: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8001
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4844FC14, Destination Call Id=18228, Source Call Id=18229,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Apr 21 10:51:25 BST: //18229/5623EE478B9D/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7129)
Apr 21 10:51:25 BST: //18228/5623EE478B9D/CCAPI/cc_api_caps_ack:
7 Replies 7
Brian Meade
Level 7
Level 7
Usually you would expect the carrier to send a Disconnect message in response to the progress message with unallocated number.
There may be a way to convert the progress message to a disconnect message but I can't remember off the top of my head.
Try this...voice call disc-pi-off
I have added that command but no luck,still getting ring back for unallocated numbers
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0002
Sending Complete
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
Called Party Number i = 0xA1, '349544'
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349544
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x475EB9D4, Call Info(
   Called Number=349544(TON=National, NPI=ISDN),
Apr 24 15:29:02 BST: //-1/9D9896348D5D/CCAPI/ccCheckClipClir:
Apr 24 15:29:02 BST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 24 15:29:02 BST: :cc_get_feature_vsa malloc success
Apr 24 15:29:02 BST:  cc_get_feature_vsa count is 131
Apr 24 15:29:02 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1220009056,feature_id:31202
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=349544(TON=National, NPI=ISDN))
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_process_call_setup_ind:
   Event=0x471BA208
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallSetContext:
   Context=0x48CCFD14
   >>>>CCAPI handed cid 31204 with tag 9 to app "_ManagedAppProcess_Default"
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallProceeding:
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=349500, Params=0x488C3E80, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCheckClipClir:
   Destination Pattern=349..., Called Number=349544, Digit Strip=FALSE
   Guid=9D989634-CAF3-11E3-8D5D-001BD4391750, Outgoing Dial-peer=349500
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=90
   cisco-anitype=2
   cisco-aniplan=0
   cisco-anipi=2
   cisco-anisi=3
   dest=349544
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46CC1C84, Interface Type=1, Destination=, Mode=0x0,
   Called Number=349544(TON=National, NPI=ISDN), Calling Translated=FALSE,
Apr 24 15:29:02 BST:  cc_get_feature_vsa count is 132
Apr 24 15:29:02 BST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1220018776,feature_id:31203
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccIFCallSetupRequestPrivate:
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccCallSetContext:
   Context=0x488C3E30
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccSaveDialpeerTag:
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8002
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_set_called_ccm_detected:
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_call_proceeding:
   Interface=0x46CC1C84, Progress Indication=NULL(0)
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_call_cut_progress:
   Interface=0x46CC1C84, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccCallCutProgress:
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=31204
Apr 24 15:29:02 BST: //31204/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4877D144, callID1=0x79E4, callID2=0x79E5, tag=0x0)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/ccConferenceCreate:
   Conference Id=0x4877D144, Call Id1=31204, Call Id2=31205, Tag=0x0
Apr 24 15:29:02 BST: //31204/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x36BB, Source Interface=0x475EB9D4, Source Call Id=31204,
   Destination Call Id=31205, Disposition=0x0, Tag=0xFFFFFFFF
Apr 24 15:29:02 BST: //31205/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr 24 15:29:02 BST: cc_api_get_xcode_stream : 4381
Apr 24 15:29:02 BST: //31205/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x36BB, Source Interface=0x46CC1C84, Source Call Id=31205,
   Destination Call Id=31204, Disposition=0x0, Tag=0x0
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x36BB, Destination Call Id=31205)
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x36BB, Destination Call Id=31204)
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46CC1C84, Destination Call Id=31205, Source Call Id=31204,
Apr 24 15:29:02 BST: //31204/9D9896348D5D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x36BB, Call Id1=31204, Call Id2=31205
Apr 24 15:29:02 BST: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8002
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x475EB9D4, Destination Call Id=31204, Source Call Id=31205,
Apr 24 15:29:02 BST: //31205/9D9896348D5D/CCAPI/cc_api_caps_ack:
Try ..voice call send-alert in global config.
Hi Saif,
Do u remember how u resolved this issue, am facing the same issue
Hi.
To add a tip to what correctly suggested by Manish (+5), on outgoing dialpeer try to add:
progress_ind setup enable 3
progress_ind alert enable 8
Carlo
Please rate all helpful posts "The more you help the more you learn"
Ayodeji Okanlawon
In addition to everything that my honourable friends have said here, I just wanted to point out the ff:
1. Its not the provider that is not sending disconnect. Its your gateway that is playing an announcement during a disconnect event. Your telco is just playing what your gateway is sending.
2. From the logs above your gateway is sending a progress message during a disconnect, hence the suggestion from Manish. This will remove the progress indicator during the disconnect and will just send a disconnect to your provider.
Please rate all useful posts
