Warning message
I need help with a backup solution to 3 Cisco 3750
Answered Question
Apr 22nd, 2014
I am in the middle of a  a big project and i am stack and need your help. i have been ask to come with the best way to configure and back up 3 cisco 3750g 48 ps switch. let me add more details,  i have two cabinets:
1. Main cabinet there need to be 2 Cisco 3750 that configure as one.
2. Second cabinet there is only one Cisco 3750. and it is located 20 maters from the main C.
my boos want me to Find the best way to back up all the switches in case of a crash.
i need to Specify that the servers that will be install in the main cabinet wont be in the second one. because the second one is the DR.
My
My solution is:
1. In the main cabinet add a third switch and configure the 3 switches in stack mode.
2. In the second cabinet add one more switch and configure them at stuck mode.
Best Regards,
michel vaillancourt
Correct Answer by Leo Laohoo about 3 years 3 months ago
The benefit of using a stack of 3750 is that they "SHARE" the configuration among themselves.  If one fails, the others carry on their work and configuration.  Logically, a stack of 3750 is one big logical switch.  That is true HA.
My recommendation is to move your 3750 together and stack them.  Re-run the fibre and/or copper back to the new stack.  This is the best way.  You don't need to bother about HSRP, STP, etc.
One of the benefits of doing this is when you dual home a server.  When you dual home a server to two separate logical switches, it's basically impossible.   However, if you dual home a server to a single logical switch, then it's as easy as configuring "NIC teaming" on the server side and enabling etherchannel on the stack 3750 side.
Overall Rating: 5 (1 ratings)
Leo Laohoo Tue, 04/22/2014 - 04:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you plan to backup the configuration of the switches, then do you have a TFTP server to store them?
If you plan to backup the IOS of the switches, I'd ask this:  Are you serious????  The best way to "backup" the IOS is to go to the Cisco website and download the IOS.
laurendvir Wed, 04/23/2014 - 00:34
i need the HA option in case of one of the swithes will crash.
Leo Laohoo Wed, 04/23/2014 - 00:54
  • Hall of Fame,
    2017 LAN, Wireless
You need to elaborate further because you are using 3750 switches and that's HA for you.
laurendvir Wed, 04/23/2014 - 05:09
i know that but my problem is that they ask to merge 2 3750 switch to act as one becuse they need more then 48 ports, and i need to have HA to the 2 swithes.
Correct Answer
Leo Laohoo Wed, 04/23/2014 - 14:43
  • Hall of Fame,
    2017 LAN, Wireless
laurendvir Mon, 04/28/2014 - 03:14
thank you for your help:-)you have been very helpful....
Leo Laohoo Sun, 05/04/2014 - 20:07
  • Hall of Fame,
    2017 LAN, Wireless
Thank you very much for taking the time to rate our posts.  :)
Archive
 Log config
 Logging enable
 Notify syslog
 Path ftp:// youftpip/youftppath/$h
Ip ftp username ftpusername
Ip ftp pass yourftppass
This will save all command on syslog, each time you copy run start, and it will save your config every 3 days automatically.
Hope this help, byw ciscoprime will do this for you as well.
laurendvir Wed, 04/23/2014 - 00:31
Hi,I am talking about high availability. in case of a crash.lauren
