Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927881members
1240935discussions
Community Activity
Answer phone
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work. I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto an...
matee by Level 1
  • 190 Views
  • 7 replies
Delink router configuration
I tried to connect my new delink router from other primary delink router for WIFI only. Can someone explain step by step for configuration
mmkb by Level 1
  • 33 Views
  • 0 replies
Redistribute routes on ABR router having Area0 and Area 13
Rtr1 ----Cost1-----> Rtr2 (Area13)Rtr1 ----Cost1-----> Rtr3 (Area13)Rtr2 ----Cost10----> Rtr3 (Area10)Rtr2 ----Cost10----> Rtr4 (Area0) If i redistribute static route on Rtr2 then Rtr3 learns best route from Rtr1If i redistribute static route on Rtr4...
AP Status joined but obb error image download
My ap Is joined but l got errors with obb AP-model ap-air2802i-b-k9 wireless controller 9800-CL 17.9.4  [*04/20/2024 19:08:59.6159] Discovery Request sent to 192.168.178.150, discovery type STATIC_CONFIG(1)[*04/20/2024 19:08:59.6432] Discovery Reques...
lisavbedt by Level 1
  • 117 Views
  • 8 replies
Disable PPTP and L2TP server
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
mo01 by Level 1
  • 84 Views
  • 3 replies
Uccx with sip
I have script with toll free number(sip) the caller sometimes hear all audio prompts in menu, and sometime hear some audio prompts which not stable, but when I dial internally the trigger it is stable and I can hear all audio prompts in menu, What co...
matee by Level 1
  • 221 Views
  • 2 replies
