Cisco ASA 5505 and PAT
Apr 22nd, 2014
So I have a weird problem that I'm hoping someone has a point in the right direction I can follow... At home I have a Cisco ASA 5505 - not very complex network some BCP configs and it's providing a NAT (PAT). I have a static IP and using a few RFC 1918 segments - like I said nothing earth shattering. I have a linksys E1200 802.11N WPA2 PSK - again pretty standard. I connect laptops, iPads, iPhones, Kindles, Androids no problem. Until recently my 60" Vizio had no issues using the network (wired or wireless). Now network is failing on the TV. I see it get to the FW and I can ping trace etc... to the TV. The FW logs show resets (log is below).
Now here is the real interesting part - if I turn the tether feature on my iPhone on and connect the TV to it - it works - what's even more interesting is if I then go back to the home network it all works again no problem until I reboot the TV... HELP!
Apr 19 15:34:09 192.168.10.254 %ASA-6-305011: Built dynamic TCP translation from inside:10.10.10.139/60657 to outside:68.162.222.142/57003
Apr 19 15:34:09 192.168.10.254 %ASA-6-302013: Built outbound TCP connection 61988 for outside:98.137.204.251/443 (98.137.204.251/443) to inside:10.10.10.139/60657 (68.162.222.142/57003)
Apr 19 15:34:09 192.168.10.254 %ASA-6-302014: Teardown TCP connection 61988 for outside:98.137.204.251/443 to inside:10.10.10.139/60657 duration 0:00:00 bytes 3689 TCP Reset-I
Apr 19 15:34:12 192.168.10.254 %ASA-6-305011: Built dynamic TCP translation from inside:10.10.10.139/60658 to outside:68.162.222.142/53332
Apr 19 15:34:12 192.168.10.254 %ASA-6-302013: Built outbound TCP connection 61989 for outside:98.137.204.251/443 (98.137.204.251/443) to inside:10.10.10.139/60658 (68.162.222.142/53332)
Apr 19 15:34:12 192.168.10.254 %ASA-6-305011: Built dynamic TCP translation from inside:10.10.10.139/37006 to outside:68.162.222.142/40015
Apr 19 15:34:12 192.168.10.254 %ASA-6-302013: Built outbound TCP connection 61990 for outside:98.136.10.32/443 (98.136.10.32/443) to inside:10.10.10.139/37006 (68.162.222.142/40015)
Apr 19 15:34:12 192.168.10.254 %ASA-6-302014: Teardown TCP connection 61989 for outside:98.137.204.251/443 to inside:10.10.10.139/60658 duration 0:00:00 bytes 3689 TCP Reset-I
Apr 19 15:34:12 192.168.10.254 %ASA-6-302014: Teardown TCP connection 61990 for outside:98.136.10.32/443 to inside:10.10.10.139/37006 duration 0:00:00 bytes 3689 TCP FINs
A
Jose Orozco Thu, 04/24/2014 - 20:12
  • Cisco Employee,
Hello ras,
As you mentioned the TV is sending a reset packet to the remote address. I will recommend you to create a capture of the traffic and review the traffic at the packet level to see a posible reason for the drop.
Here is how. Then you can download it to pcap format and uploaded to the forum for further analysis.
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-nex...
http://www.cisco.com/c/en/us/td/docs/security/asa/syslog-guide/syslogs/l...
Hope this information is helpful.
Related Content
