04-23-2014 03:09 AM - edited 03-07-2019 07:11 PM
We are using cisco core switch RPVST mode.
we normally enabled Root-guard on CoreSwitch trunk port connected to access switch
From Access switch port connected with Core switch, we enable loop-guard
Query is " do we need to enable loop-guard in between x-connect of core switches, as per loop-guard definition - Loop guard must be enabled on the non-designated ports (more precisely, on root and alternate ports) for all possible combinations of active topologies
In my case , For even vlan core switch 1 is root, odd vlan core switch 2 is root.
from Core 1
VLAN0904 Desg FWD 2 128.130 P2p
VLAN0995 Root FWD 2 128.130 P2p
From Core 2
VLAN0904 Root FWD 2 128.130 P2p
VLAN0995 Desg FWD 2 128.130 P2p
Br/Subhojit
04-23-2014 03:54 AM
It won't hurt if you configure loopguard on all ports. You can even enable loopguard globally by issuing spanning-tree loopguard default.
04-23-2014 04:35 AM
What will be the pros/cons of the same when we enable loop-guard in x-connect
br/subhojit
04-23-2014 09:07 AM
Any further input....
04-23-2014 12:24 PM
