04-23-2014 06:10 AM - edited 03-07-2019 07:11 PM
Hello colleagues.
I've got some problem with MAB (mac address bypass) and catalyst 3750 stack (consist of 3 switches). I configured MAB on this stack, it works via radius with ACS 5.5.
This is globlal config:
aaa authentication dot1x default group MAB20 group MAB21
aaa authorization network default group MAB20 group MAB21
aaa accounting dot1x default start-stop group MAB20 group MAB21
This is port config:
switchport access vlan 4094
switchport mode access
switchport nonegotiate
switchport block multicast
switchport block unicast
switchport voice vlan 2620
ip device tracking maximum 2
load-interval 30
small-frame violation-rate 10000
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
authentication host-mode multi-domain
authentication port-control auto
mab
storm-control broadcast level pps 500
storm-control action trap
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input PM-VOIP
ip dhcp snooping limit rate 100
Everything works fine, switch asks ACS if device with this mac adress is allowed to access the network, ACS says yes or no and assignes appropriate VLAN for this device.
If you type "no mab" command on the not connect port (down down) it works fine. But (!!!) if you type "no mab" command on the port that is trying to authenticate - master swicth (master in stack) fails and reboots!!! Other 2 switches works fine.
Here is some "show log":
000077: Apr 17 14:51:00: %PLATFORM-1-CRASHED: System previously crashed with the following message:
000078: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2)
000079: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Technical Support: http://www.cisco.com/techsupport
000080: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Copyright (c) 1986-2010 by Cisco Systems, Inc.
000081: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Compiled Sat 07-Aug-10 22:45 by prod_rel_team
000082: Apr 17 14:51:00: %PLATFORM-1-CRASHED:
000083: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
000084: Apr 17 14:51:00: %PLATFORM-1-CRASHED:
000085: Apr 17 14:51:00: %PLATFORM-1-CRASHED: SRR0 = 0x02AD5340 SRR1 = 0x00029230 SRR2 = 0x013EFDDC SRR3 = 0x00029230
000086: Apr 17 14:51:00: %PLATFORM-1-CRASHED: ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x01000000
000087: Apr 17 14:51:00: %PLATFORM-1-CRASHED:
000088: Apr 17 14:51:00: %PLATFORM-1-CRASHED: CPU Register Context:
000089: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Vector = 0x00002000 PC = 0x013EFDDC MSR = 0x00029230 CR = 0x55003033
000090: Apr 17 14:51:00: %PLATFORM-1-CRASHED: LR = 0x013EFDC4 CTR = 0x013E642C XER = 0xA0000014
000091: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R0 = 0x013EFDC4 R1 = 0x05522F78 R2 = 0x00000000 R3 = 0x02F273E0
000092: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R4 = 0x031E13D4 R5 = 0x000000F4 R6 = 0x05522E20 R7 = 0x000000E7
000093: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R8 = 0x001D78A0 R9 = 0x00000000 R10 = 0x00000000 R11 = 0x050B70AC
000094: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R12 = 0x0105A439 R13 = 0x00110000 R14 = 0x013E6874 R15 = 0x00000000
000095: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
000096: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
000097: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R24 = 0x00000002 R25 = 0x002130B4 R26 = 0x00000004 R27 = 0x050B6330
000098: Apr 17 14:51:00: %PLATFORM-1-CRASHED: R28 = 0x03920000 R29 = 0x031E13D4 R30 = 0x00000003 R31 = 0x003398A0
000099: Apr 17 14:51:00: %PLATFORM-1-CRASHED:
000100: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Stack trace:
000101: Apr 17 14:51:00: %PLATFORM-1-CRASHED: PC = 0x013EFDDC, SP = 0x05522F78
000102: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 00: SP = 0x05522F90 PC = 0x013EFDC4
000103: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 01: SP = 0x05522FD0 PC = 0x013F0978
000104: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 02: SP = 0x05522FE8 PC = 0x013F213C
000105: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 03: SP = 0x05523008 PC = 0x013FA6A8
000106: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 04: SP = 0x05523020 PC = 0x013FA8B4
000107: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 05: SP = 0x05523050 PC = 0x02AA85F8
000108: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 06: SP = 0x05523058 PC = 0x013FB580
000109: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 07: SP = 0x05523078 PC = 0x013E6944
000110: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 08: SP = 0x05523080 PC = 0x01BB7308
000111: Apr 17 14:51:00: %PLATFORM-1-CRASHED: Frame 09: SP = 0x00000000 PC = 0x01BADD78
000112: Apr 17 14:51:00: %PLATFORM-1-CRASHED:
000329: Apr 22 14:13:21: %STACKMGR-4-SWITCH_REMOVED: Switch 3 has been REMOVED from the stack
000330: Apr 22 18:13:21.143: license_init_config_queue: initializing the license_switch_boot_config_q
000331: Apr 22 14:13:21: %STACKMGR-4-MASTER_ELECTED: Switch 1 has been elected as MASTER of the stack
000332: Apr 22 14:13:21: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
000333: Apr 22 14:13:22: %CFGMGR-6-APPLYING_RUNNING_CFG: as new master
000334: Apr 22 14:13:22: %SSH-5-ENABLED: SSH 1.99 has been enabled
000335: Apr 22 14:13:23: %RADIUS-4-NOSERV: Warning: Server 11.11.11.10:1645,1646 is not defined.
000336: Apr 22 14:13:23: %RADIUS-4-NOSERV: Warning: Server 11.11.11.11:1645,1646 is not defined.
000337: Apr 22 14:13:23: %AAAA-4-BADMETHNAME: Bad authentication method-list name "TACACS" (this is only a warning)
000338: Apr 22 14:13:23: %SYS-6-CLOCKUPDATE: System clock has been updated from 18:13:23 MSK Tue Apr 22 2014 to 18:13:23 MSK Tue Apr 22 2014, configured from console by vty0.
000339: Apr 22 14:13:23: %RADIUS-3-NOSERVERS: No Radius hosts configured or no valid server present in the server group MAB20
000446: Apr 22 14:16:04: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
000447: Apr 22 14:16:04: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
000448: Apr 22 14:16:37: %STACKMGR-4-SWITCH_ADDED: Switch 3 has been ADDED to the stack
000328: Apr 22 14:16:37: %STACKMGR-4-SWITCH_ADDED: Switch 3 has been ADDED to the stack (C375048PS-2)
000449: Apr 22 14:17:09: %STACKMGR-5-SWITCH_READY: Switch 3 is READY
000450: Apr 22 14:17:09: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 3 has changed to state UP
000451: Apr 22 14:17:09: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 3 has changed to state UP
000329: Apr 22 14:17:09: %STACKMGR-5-SWITCH_READY: Switch 3 is READY (C375048PS-2)
*Mar 1 00:02:19.972: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack (C375048PS-SWC-3)
*Mar 1 00:02:19.972: %STACKMGR-4-SWITCH_ADDED: Switch 2 has been ADDED to the stack (C375048PS-SWC-3)
*Mar 1 00:02:19.972: %STACKMGR-4-SWITCH_ADDED: Switch 3 has been ADDED to the stack (C375048PS-SWC-3)
*Mar 1 00:02:24.133: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan (C375048PS-SWC-3)
000005: *Apr 22 14:16:46: %SYS-6-CLOCKUPDATE: System clock has been updated from 14:16:46 UTC Tue Apr 22 2014 to 18:16:46 MSK Tue Apr 22 2014, configured from console by console. (C375048PS-SWC-3)
000006: *Apr 22 14:17:08: %SYS-5-CONFIG_I: Configured from memory by console (C375048PS-SWC-3)
000007: *Apr 22 14:17:09: %STACKMGR-5-SWITCH_READY: Switch 1 is READY (C375048PS-SWC-3)
000008: *Apr 22 14:17:09: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY (C375048PS-SWC-3)
000009: *Apr 22 14:17:09: %STACKMGR-5-SWITCH_READY: Switch 2 is READY (C375048PS-SWC-3)
000010: *Apr 22 14:17:10: %SYS-5-RESTART: System restarted -- (C375048PS-SWC-3)
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2) (C375048PS-SWC-3)
Technical Support: http://www.cisco.com/techsupport (C375048PS-SWC-3)
Copyright (c) 1986-2010 by Cisco Systems, Inc. (C375048PS-SWC-3)
Compiled Sat 07-Aug-10 22:45 by prod_rel_team (C375048PS-SWC-3)
000011: *Apr 22 14:17:10: %STACKMGR-5-SWITCH_READY: Switch 3 is READY (C375048PS-SWC-3)
Did anyone faced this problem? How did you fix this?
Thanks.
04-23-2014 09:22 AM
That's going to be something you are going to have to go the cisco TAC with . That looks to be some kind of software bug. Also a feature probably not a lot of people actually use and have knowlwedge about.
04-24-2014 02:21 AM
Thank you for your advice.
