04-23-2014 07:47 AM - edited 03-16-2019 10:33 PM
Do you need a port license in integrating CUCME and CUE?
Solved! Go to Solution.
04-23-2014 08:20 AM
Hi Ramon,
Yes you would require Port licenses for this integration (increments of 2)
The following types of licenses are available:
•Mailboxes (available only in increments of five)
•Ports (available only in increments of two)
•IVR (available only in increments of two)
•TimeCardView users (available only in increments of one)
The corresponding SKUs for these licenses are:
•FL-CUE-MBX-5
•FL-CUE-PORT-2
•FL-CUE-IVR-2
•FL-TCV-USER-1
To determine the total quantity of licenses you need, multiply the incremental quantity from the name of the CSL license with the explicit quantity of increments that you want to purchase. For instance, FL-CUE-MBX-5 represents an incremental quantity of five mailboxes. If you select an explicit quantity of four for the FL-CUE-MBX-5 feature, the total quantity will be five times four, or 20.
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html#wp1102792
Cheers!
Rob
Please support CSC helps Kiva
https://supportforums.cisco.com/blog/12122171/cisco-support-community-helps-kiva
04-23-2014 08:35 AM
Hi Rob,
In addition to what Rob has said[+5] , you would be requiring licenses for Mailboxes and Voice Port licenses.
You can also refer the ordering guide for more details.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps4625/cme_ordering_guide.pdf
regds,
aman
04-23-2014 08:20 AM
Hi Ramon,
•FL-CUE-MBX-5
•FL-CUE-PORT-2
•FL-CUE-IVR-2
•FL-TCV-USER-1
Cheers!
Rob
04-23-2014 08:35 AM
Hi Rob,
regds,
aman
