04-23-2014 01:18 PM - edited 03-07-2019 07:11 PM
I want to upgrade the cisco nexus 5548 from 5.2.1 to 7.x image. Can I upgrade it directly to 7.x version or not?
04-23-2014 03:38 PM
Yes, you can. There is a USB flash port on the switch you can use to copy the file to the internal flash.
04-26-2014 09:03 PM
It depends how you want to do it.
1. ISSU
2. Traditional via, Changing boot variable and reload.
With ISSU you cant go directly from 5.X to 7.X, There will be a path which has to be followed and by the way this does not require a Reload.
With option 2 you just change the boot variable and reload the box and it will come up with the new image.
So let me know your requirement and i will let you know that upgrade path.
Seemab
