Hello, is there a chart of some sort that explaining all the attributes in the "show interface gig x/x"? command:
12627282818 packets input, 13956410964813 bytes, 0 no buffer
Received 75789 broadcasts (75035 multicasts)
0 watchdog, 75035 multicast, 0 pause input
11978362642 packets output, 14652129899933 bytes, 0 underruns
I understand that that Runts are frames recieved under 64 bytes, Giants over 1518 bytes, but why? For example late collisions are normally duplex issues, cable issue or length of cable...
I am just lookig for something so I can do a lookup if I get any of the errors above (runts, giants, throttles, CC, watchdog, babbles, etc)
