04-24-2014 02:20 AM - edited 03-07-2019 07:12 PM
i have new 2960s switch
am not allowed to connect it to network before upgrade IOS
seems that i must use xmodem
problem is after file finishes copying to flash i get a i/o error from xmodem
and cannot do boot flash:newios.bin
what could the problem be?
thanks
04-24-2014 03:42 AM
I don't understand why you didn't connected your PC directly to your switch only (not to network yet) and did the upgrade much faster using stangard TFTP process?
BTW this name "newios.bin" - i suppose it's only for forum message because there is no need for changing IOS name...
BR,
Dragan
04-24-2014 04:34 AM
was interested to try xmodem for learning reasons ( ios is corrupt etc.)
+ direct to pc needs config of ip and passwords
thanks
04-24-2014 04:36 AM
Learning - great ... I thought it was something for production needs...
IP configs and passwords is also learning
But whatever reason you find - keep the good work on!
BR,
Dragan
04-24-2014 04:47 AM
production but with a chance to learn something..
so any ideas about why i cant copy the file with xmodem
thanks.
04-24-2014 04:51 AM
cisco.com only way for you...check this link if you didn't already:
BR,
Dragan
