Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927470members
1240191discussions
Community Activity
SD-WAN vEdge Upgrade path
Hello, team. Good day.   We are planning to upgrade below platforms to 20.9.x. Is there any upgrade path ?   - vEdge 5000 20.3.3 - vEdge 2000 20.6.3 - ISR1100-6G (Viptela OS) 20.6.3   Thanks.
jjpark by Level 1
  • 0 Views
  • 0 replies
How Do I Really Get Through To British Airways? Contact Us
How Do I Really Get Through To British Airways? To speak with a human at British Airways immediately, dial the customer support number £$ ퟭ-805 ✈ 309 ✈ 9377 or ퟭ-805 ✈ 309 ✈ 9377 . After the automated message, press the appropriate number to connec...
tan2234 by Level 1
  • 0 Views
  • 0 replies
Site-to-Site IPSec with VTI - Initial delay up to 60 seconds
Hello,I have an IKEv2 Site-to-Site IPSec tunnel (VTI with static routing) between ASA firewall and 2 stateless HA routers configured with HSRP (IPSec end point is HSRP VIP hosted on the HSRP active router).Despite the fact it is not stateful (not sup...
VPC Link Down
Hi anyone can assist me on the VPC configuration ? The status not up. VPC Status : switch(config)# show vpcLegend:(*) - local vPC is down, forwarding via vPC peer-link vPC domain id : 700Peer status : peer link is downvPC keep-alive status : Suspende...
Muhd by Level 1
  • 110 Views
  • 4 replies
Setting UP a SECOND ASA5506-x firewall
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
EEM scripting help
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 62 Views
  • 2 replies
SRTP config
Hi All, I'm trying to establish a SIP trunk to an ITSP using TLS and SRTP. We think we have done all the trust point stuff and TLS seems to be OK. However, I'll a little lost on the SRTP. Looking at several guides looks like a few different methods. ...
Agent cannot change the status of working with chats
Hello world,The agent cannot change the status to work with chats “Out of Service (error condition)” associated with  NonVoiceControlGadget.The error is not associated with the agent's PC. If you use a different agent login, there is no problem.Re-cr...
bokunau by Level 1
  • 16 Views
  • 0 replies
