Warning message
Moving ASA config from 5510 to 5512
Apr 24th, 2014
I moved a configuration from an ASA 5510 to a 5512, and in the process, went from version 8.4 to 9.0 of the IOS software.  When we hook the firewall up, I can get to it from SSH, or from the outside, but a number of the NATS don't appear to be up, VPN connections via the client don't work, and there is a L2L VPN Tunnel that isn't working either.
The only differences between the configs are the RSA key, which I had to regenerate for the new firewall, and I had to manually install the cert.  I can't imagine where either of those would affect IP NATs though.
Curiously, all of the NATs that aren't working appear to be on a separate external subnet than the ones that are working, but those networks aren't defined in either config.
Suggestions?
Marvin Rhoads Thu, 04/24/2014 - 21:26
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Have a look on disk0:. There should be a startup errors file that lists the issues the parser had when it converted the file.
dustin.kinn Thu, 04/24/2014 - 21:32
I'll check that tomorrow.  It didn't convert the file though, I pasted it from one ASA to the other, then went through line by line to make sure it was the same.
Only differences were that the Cert didn't carry over, I had to reinput that (which again I did by cut and paste, which might be wrong, I'm a total noob when it comes to certs), and there are a few new lines of code, mostly the xlate stuff from version 9.  If I read correctly, the settings it generates preserve the functionality.
There is also a line:
crypto ca trustpool policy
Which is not on the old, but it won't let me remove from the new.
Again, I can't imagine that Certs would screw up my NAT settings though.
Marvin Rhoads Fri, 04/25/2014 - 05:16
  • Hall of Fame,
If your NAT statements were based on ACLs, that could impact the setup as some ACL syntax was changed as of 9.x.
I've done a number of upgrades to 9.x though and have not encountered any issues with NAT when moving from post-8.2 platforms. (Of course 8.2 and earlier are a whole other issue.)
dustin.kinn Fri, 04/25/2014 - 11:54
I went from 8.6 to 9.0 on the new ASA, but stupidly didn't even think twice about dropping an 8.4(2) config on the new 9.0(3) firewall.  I verified my upgrade path but didn't even think about where the config was coming from.
Could that be causing my issue?  Could I downgrade the 9.0 5512 to 8.4(2) and then drop the config on, then upgrade to 9.0(3) again?
Related Content
