Warning message
7821 Registration issue
Answered Question
Apr 25th, 2014
Hi All,
We are facing some registration issues in Cisco 7821 Phone. It took more than 30 Minutes to register in CUCM. Some of the Phones not getting registered with TFTP failed.
CUCM  version 9.1.2. We have added the necessary device package in CUCM for 7821.
Phone Active firmware:10-1-1-9
Thanks in Advance.
Overall Rating: 5 (1 ratings)
Ajith Nayak Fri, 04/25/2014 - 04:11
Dear,
Please try this link
http://software.cisco.com/download/release.html?mdfid=284510097&flowid=45900&softwareid=282074299&release=9.1%282.11012%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Left hand side you will have latest device pack
Cisco Unified Communications Manager 9.1(1.21010) Device Package - Compatible UCM Version: 9.1
cmterm-devicepack9.1.1.21010-1.cop.sgn
Hope It should get fixed even I had the same issue if not that then try the latest.
13-MAR-2013640.14 MB
gpsriramdc Fri, 04/25/2014 - 04:35
Hi Ajith,
In our case some of the phones are registered & partial phones are having the problem. CUCM configuration , TFTP Server , Voice VLAN everything is identical as same as working phone.
But in the Phone configuration i couldn't see the UCM IP Address.
Aman Soi Fri, 04/25/2014 - 05:03
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Did you  try physically rebooting the phone and check what happens?
regds,
aman
gpsriramdc Wed, 05/07/2014 - 18:13
Thanks Nagarajan.
We have resolved this by upgrading CUCM to ES version for the specific bugfix.
Cesar Adrian Ga... Wed, 05/07/2014 - 15:48
Hi Everyone, I have the same issue, is a new clean installation with the upgrade of the dev. pack I can add all the phones but stills in register, with others phones is working fine 7965 phones and CIPC, any answer with thiss issue.
Best regards.
CG
