Warning message
IP phone 7911 deceased
Apr 25th, 2014
Hi ! Hope you guys know more than me about VoIP ! I'm having a problem with my ip phone model 7911, it was working fine but suddenly stopped. That is the output from the cme:
ephone-77[76] Mac:001E.135C.BA11 TCP socket:[-1] activeLine:0 whisperLine:0 DECEASED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:172.25.7.220 001E.* 50697 7911  keepalive 69 max_line 1 available_line 1
button 1: cw:1 ccw:(0 0)
  dn 77 number 5277 CH1   DOWN         CH2   DOWN
any ideas?
Cheers
manpreet singh Fri, 04/25/2014 - 04:58
Try recreating the cnf files under telephony-service:
config t
telephony-service
cnf-file perphone
no create cnf
create cnf
Then, reset the ephone:
config t
ephone xx
reset
If this is happening frequently than check if you have rogue DHCP server. Check the DHCP ip address from the phone settings and see if it is the correct one.
gabriela.kca Wed, 04/30/2014 - 00:18
Hi Manpreet ! Thank you for your advice. I will try that today,but I have a quick question. will this affect my other phones which are connected to the same CME router?
Cheers
