Warning message
Vlan Trunk Between Dell PowerConnect 5324 and Cisco Cisco 2811 (Intervlan-routing)
Apr 25th, 2014
Hi Everybody:
Im conecting a phisical trunk, between  switch Dell PowerConnect 5324 and Cisco 2811 Router, please see the attachment topology, I can't not ping between the PC A and PC B, I will show the configs:
The config in the router CISCO:
interface FastEthernet0/0
 description Cisco to Trunk DELL
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.2
 description VLAN 2
 encapsulation dot1Q 2 native
 ip address 200.71.155.193 255.255.255.248
interface FastEthernet0/0.3
 description VLAN 3
 encapsulation dot1Q 3
 ip address 201.249.204.153 255.255.255.248
Config DELL POWERCONNECT:
Configuring VLAN Trunk in Ethernet G23 :
interface ethernet g23
switchport mode trunk
switchport trunk allowed vlan add 2,3
exit
ADDING VLAN 2 AND 3:
enable
configure
vlan database
vlan 2
vlan 3
exit
Configuring Ports  E2 , E3 in VLANS 2, 3 respectivily:
interface ethernet e2
switchport mode access
switchport access vlan 2
exit
interface ethernet e3
switchport access vlan 3
exit
copy running-config startup-config
Could you tell me what is missing on my config? Thanks in advance.
Jon Marshall Fri, 04/25/2014 - 06:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I'm not familiar with that make of switch but have you made vlan 2 the native ie. untagged vlan on the switch ?
If not then it may be easier on the 2811 to simply change -
int fa0/0.2
encapsulation dot1q 2 native
to
int fa0/0.2
ie. remove the native keyword and retry.
Jon
sistemastel Fri, 04/25/2014 - 06:53
Thanks you, I am going to do that, it is true, because I dont configure native VLAN on DELL switch, may be this is the problems cause.
