Warning message
help with WIC-1DSU-T1v2 in 2620
Apr 25th, 2014
The serial int that has a WIC-1DSU-T1v2 in my 2620 router says status is down down. The light in the back is AL - amber and CD - green. The interface also has the following status: DCD=down  DSR=up  DTR=up  RTS=up  CTS=down
I had the isp test the connection to the demarc and they are saying everything is fine on their side. Please help me troubleshoot.
Reza Sharifi Fri, 04/25/2014 - 21:03
  • Cisco Designated VIP,
    2017 LAN
Is the cable inserted all the way into the serial port?
Also, do you have a different serial card to test with?
Is the cable ok?
You may have a bad card
irotsenmar1 Mon, 04/28/2014 - 12:28
Yes, the cable is inserted all the way. I don't have another card to test with. It has been working before and all of a sudden one day it stopped. How can I tell if I have a bad card? Thanks.
irotsenmar1 Mon, 04/28/2014 - 12:31
The card was working before and all of a sudden stopped recently. Not sure why. The document says that the 2620xm is supported.
pompeychimes Mon, 04/28/2014 - 12:37
  • Bronze, 100 points or more
Make a loopback plug and see if it comes up. Search google for instructions.
irotsenmar1 Mon, 04/28/2014 - 12:45
When I insert the loopback plug, what should I be looking for exactly? lights? statistics? Can you please describe in detail? Thanks.
irotsenmar1 Mon, 04/28/2014 - 13:07
I did everything you mentioned. The interface is up/up and I can ping to its own IP address and the other interface FastEthernet IP address also. What should I do next? Thanks.
pompeychimes Mon, 04/28/2014 - 13:13
Sounds like you have a telco issue or if applicable an extended wiring issue. Have you called the telco and/or verified the wiring?
