Cisco 7821 phones
 - CUCM Version 9.1.2.
 - Newly deployed Cisco 7821 phones in cluster
 - facing issue with registration, showing UNKNOWN for some of the phones
 - if I reset the registered phone taking 30 min to register again
 - even if i update the Line page, its taking 30 mins to register
 - TFTP is not responding to the phone request for the file j9-tzdata.jar.sgn
 - Any idea regarding this issue
Hii,
I upload the file and I don't receive any error, I restart the TFTP and CallManger and the problem is still on.
I check on TFTP and I don't find the file with the name:
 j9-tzdata.jar.sgn
The Phone still restarting and register and restart :(
24 Replies 24
Manish Prasad
Level 5
Level 5
I think you need Dev pack.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
This I have already updated with latest dev pack, but still facing the issue
Did you restarted cluster after installing dev pack ? To registered phone properly a cluster reboot required otherwise you could face problem like this.
Yes I have rebooted the entire cluster after upgrading with new device packs, We have done the same upgrade for 5 cluster, the phone deployment has just started with this cluster and we stuck to proceed to different cluster too.
Can you try packet capture when you reset one of the 7821. I guess the load version would be 78xx.10-1-1-9.
Manish
TFTP Traces
05760453.000 |21:46:43.994 |AppInfo  |   TID[854ffb90] HTTPEngine::getRequest(), [0x9abefd28~368~10.246.38.33~51124] File Requested j9-tzdata.jar.sgn
05760454.000 |21:46:43.994 |AppInfo  |<--TID[854ffb90] HTTPEngine::getRequest(), [0x9abefd28~368~10.246.38.33~51124]
05760455.000 |21:46:43.994 |AppInfo  |-->CReqContext::tftp[0x9abefd28~368~10.246.38.33~51124]
05760456.000 |21:46:43.994 |AppInfo  |CReqContext::CheckAndSetIsStatic(j9-tzdata.jar.sgn) is (Static) File
05760457.000 |21:46:43.994 |AppInfo  |CReqContext::FindAndServe SignFileFlag[0]
05760458.000 |21:46:43.995 |AppInfo  |   CReqContext::tftp[0x9abefd28~368~10.246.38.33~51124] j9-tzdata.jar.sgn file not found. Checking [j9-tzdata.jar] to sign
I found a solution to fix the issue by following the below steps
tzupdater.jar - Downloaded the file from TFTP server
Rename and change the formart as j9-tzdata.jar.sgn.
Uploaded the file into our TFTP server
Issue fixed.
That's a timezone updater java file. Glad that issue has been resolved.
If 7821 with load ver 10-1-1-9 is looking for j9-tzdata.jar.sgn then that file should be there in the device pack , i think this is something which Cisco can answer better.
Manish
[+5] to Manish  and Nagarajan
this seems to be a bug.
To support new time zone file- IBM J9
CSCuj27391
Symptom:
Currently CUCM supports two format of time zone data, tzupdater.jar (RT and TNP uses it) and csv file (RTL uses it). And now we have a new phone that runs on IBM J9 (JVM), which needs new file to support update of the time zone.
Conditions:
When the following phone models are used -
SnoopyPlus Series: 7821, 7841 and 7861.
Workaround:
No workaround.
regds,
aman
Thanks Aman for finding this out.
Hey,
How to Downloaded the file ( tzupdater.jar  ) from TFTP server  ??
tftp -i [cucm ip] get tzupdater.jar
Here is the link
Error on server : Illegal TFTP operation
 Connect request failed
I manage to download the file from TFTP but not able to Sent the file to TFTP.
To upload file in cucm TFTP , you need to go OS Administration > software upgrade> tftp file management >upload file.
