WLC 2504 Web reauthentication issues
Apr 30th, 2014
We recently facing web reauthentication issue with cisco 2504 wireless controller. While a user going out of wireless network and coming back he have to authenticate again.We tried all the session timeouts settings in the controller but still the problem persist.
Is any way to keep the webauthentication session ?
Overall Rating: 5 (1 ratings)
Saurav Lodh Thu, 05/01/2014 - 05:00
  • Gold, 750 points or more
Since you are saying , you have already played with timeout settings, I would recommend you to upgrade the code.
Scott Fella Thu, 05/01/2014 - 07:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
That is how the WebAuth functions.  What you need to do is either use sleeping clients if your on v7.6 or else you need to increase the idle timeout.  This can be done on either the global setting on the main GUI page of the WLC or on the WLAN advanced tab, on new code.  The session timer has to be higher or disabled, than the idle timer.  I usually set the idle timer to 7200 or 14400 seconds (2 or 4 hours).  This give someone time to go to lunch and come back.  IF your running v7.6, then use the sleeping client feature.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guid...
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
Abhishek Abhishek Wed, 05/28/2014 - 15:41
Please upgrade to the latest version of WLC 2504 controller.
