Warning message
NO Internet access on LAN - Cisco 1941 Router
May 1st, 2014
I have a router in my company premises and i am getting problems to access internet on LAN. My router configuration is as follows:
router#show run
Building configuration...
Current configuration : 1249 bytes
! Last configuration change at 08:05:40 UTC Thu May 1 2014
version 15.2
hostname router
boot-start-marker
boot-end-marker
enable secret 4 cMKf9AseOngX7qzV669VAP6mTP7Zx2CAoLvvkpbCO1E
no aaa new-model
memory-size iomem 25
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO1941/K9 sn FGL1801222R
username admin privilege 15 secret 4 c5LFTnp3A5C3Ds2sCA3PU0Csl6Q1V1MpHyKNktEi5tI
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.100.8 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.10.10.1 255.255.255.0
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 10.10.10.0 255.255.255.0 GigabitEthernet0/0
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Please help ..... and suggest to change the configuration and please send the detailed steps to do.
Overall Rating: 4 (1 ratings)
hdussa Thu, 05/01/2014 - 01:41
why do route ip route 10.10.10.0 255.255.255.0 to GigabitEthernet0/0 ?
usually a default route points to the internet.
ip route 0.0.0.0 0.0.0.0 <ip next hop>
Horst
D.Ghanekar Thu, 05/01/2014 - 06:43
hi,,
thanks for reply...
I am a beginner in router configurations..... so please help me with the <ip next hope>..
I am trying to connect this router for testing in my office network.... My Office network is in 192.168.100.10-200 range and i given 192.168.100.8 to routers wan interface an i am trying the 192.168.100.7 as ip next hop...
Will this work ...
I can share you remote for the console of router...
hdussa Thu, 05/01/2014 - 06:57
next hop = ip address of the internet router.
D.Ghanekar Fri, 05/02/2014 - 06:09
hi,
i change the configurations as follows...
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 ip nat outside
 duplex auto
 speed auto
ip http server
ip nat inside source list 10 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.100.1
access-list 10 permit 192.168.100.0 0.0.0.255
with this i can ping the 4.2.2.2 and 8.8.8.8 and google.com IP 74.125.200.113 but on LAN interface i am unable to access the internet.
Please help.
Jon Marshall Fri, 05/02/2014 - 06:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The configuration is confusing.
You have a default route pointing to a 192.168.100.x IP and you say you can ping internet IPs from the router.
But then you have "ip nat inside" on the 192.168.100.x interface.
So -
1) what are your LAN IPs
2) what is the subnet used to connect to the internet ?
Jon
D.Ghanekar Fri, 05/02/2014 - 23:35
Hi Jon..
Actually this device id of our customers and he has a lease line ... but he reported that they found this hardware faulty and thus we are testing it by configuring in our office premises.
In our office we have network in range 192.168.100.0/24 and thus we give the ip 192.168.100.8 to routers wan port. On routers LAN port we give the ip 10.10.10.1/24.
This is the scenario.....
